查看: 1223|回复: 3
[编程申请]:在ARX编程中如何用直线模拟画圆弧
发表于 2004-5-19 19:01:21 | 显示全部楼层 |阅读模式
请教诸位高手,在ARX编程中如何用复合线模拟画圆弧?!
本人经过多次尝试均未成功,特请诸位赐教!
尤其使用startAngle()和endAngle()函数返回圆弧的起始角大于终止角时,不知如何计算圆弧上的坐标点,片段程序如下:
   double  satrtangle;  // 圆弧起始角
      double  endangle;  //原户终止角
      double   angle ,ang;  //计算圆弧上点坐标用到的角度、角度步长
      ads_point startpt ,endpt,centerpt;    //
      ang = (startangle-endangle)/100.0  //
      for( angle=startangle;angle<endangle;angle=angle+ang)
          startpt[X]=centerpt[X]+0.707*cos(angle);
          startpt[Y]=centerpt[Y]+0.707*sin(angle);
          startpt[Z]=centerpt[Z];
          endpt[X]=centerpt[X]+0.707*cos(angle+ang);
          endpt[Y]=centerpt[Y]+0.707*sin(angle+ang);
          sendpt[Z]=centerpt[Z];
发表于 2004-5-19 19:09:28 | 显示全部楼层
为什么要用直线模拟画圆弧?你把圆弧的弦计算出来,用直线连起来不就行了。
发表于 2004-5-19 19:41:37 | 显示全部楼层
  1.   [FONT=courier new]
  2. void
  3. getSamplePoints(
  4. double fromParam,
  5. double toParam,
  6. double approxEps,
  7. AcGePoint2dArray& pointArray,
  8. AcGeDoubleArray& paramArray) const;
  9. fromParam Input starting parameter
  10. toParam Input ending parameter
  11. approxEps Input chord-height tolerance
  12. pointArray Output array of points on curve between fromParam and toParam
  13. paramArray Output array of parameters corresponding to points in pointArray
  14. Returns a list of points on the curve between fromParam and toParam. The line segment between any two consecutive points returned in pointArray does not deviate by more than approxEps from the curve.
  15. --------------------------------------------------------------------------------
  16. void
  17. getSamplePoints(
  18. int numSample,
  19. AcGePoint2dArray& unnamed) const;
  20. numSample Input number of points that are to be returned
  21. unnamed Output array of sampled points
  22. Returns the specified number of points on the curve. The points are equally spaced by parameter value. So if the interval of the curve [0,1] and numSample is 5, the parameter values of the returned points will be 0, 0.25, 0.5, 0.75, and 1.
  23.   [/FONT]
复制代码
 楼主| 发表于 2004-5-21 18:55:48 | 显示全部楼层
请问斑竹,能否详细介绍getSamplePoints的用法?
GMT+8, 2026-11-5 13:13 , Processed in 0.484980 second(s), 38 queries , Gzip On.
