查看: 1359|回复: 9
[原创]:平面图转45度轴测图源程序
发表于 2004-6-4 16:14:57 | 显示全部楼层 |阅读模式
全部用纯lisp,没有vlisp,因为不会。
cad2004,2005测试通过,其它版本未测试。
未考虑z坐标及ucs
arc(pl-arc),circle由pl逼近,以实际打印长度0.2mm为控制长度,
如果弧线很长,运行速度会很慢。
可转换实体:LINE,ARC,CIRCLE,LWPOLYLINE,TEXT,INSERT,RAY,XLINE,SOLID
其中pl可为不定宽度arc及line。
属性块中属性与块作为一个整体。
提供源码,请高手指点。
[php]
;transform plan to sys
;entities can be transformed: LINE,ARC,CIRCLE,LWPOLYLINE,TEXT,INSERT,RAY,XLINE,SOLID
(defun c:pts(/ plotscale ss y-base i ssn dxfdata r len m elist n b d
               pt-start x-start y-start x-end y-end ang-start ang-end ang
               pt1 pt2 width-fixed width-start width-end width-step headerlist
               n-vertext n-vertex-end ifclose layer color linetype ltscale lineweight
               pt-start-pl pt-dummy x-end-dummy y-end-dummy oldosmode oldautosnap)
   (command "undo" "begin")
   (setq plotscale (getreal "\ninput plot scale 1:<100>:"))
   (if (not plotscale)(setq plotscale 100.0))
   (setq ss (ssget ":L"))
   (initget 1)
   (setq y-base (cadr (getpoint "\nbase point:")))
   (setq i 0)
   (repeat (sslength ss);repeat0
      (setq ssn (ssname ss i))
      (setq dxfdata (entget ssn))
      (if (= "LINE" (cdr (assoc 0 dxfdata)));if1
         (progn;1
               (setq pt-start (cdr (assoc 10 dxfdata)))
               (setq x-start (car pt-start) y-start (cadr pt-start))
               (setq x-end (+ x-start (/ (- y-start y-base) (sqrt 2.0))))
               (setq y-end (+ y-base  (/ (- y-start y-base) (sqrt 2.0))))
               (setq dxfdata (subst (list 10 x-end y-end) (assoc 10 dxfdata) dxfdata))
               (setq pt-start (cdr (assoc 11 dxfdata)))
               (setq dxfdata (subst (list 11 x-end y-end) (assoc 11 dxfdata) dxfdata))
            (entmod dxfdata)
         );progn1
      );if1
      (if (= "ARC" (cdr (assoc 0 dxfdata)));if1
         (progn;1
            (setq layer (cdr (assoc 8 dxfdata)))
            (setq color (cdr (assoc 62 dxfdata)))
            (setq linetype (cdr (assoc 6 dxfdata)))
            (setq ltscale (cdr (assoc 48 dxfdata)))
            (setq lineweight (cdr (assoc 370 dxfdata)))
            (setq r (cdr (assoc 40 dxfdata)))
            (setq ang-start (cdr (assoc 50 dxfdata)))
            (setq ang-end   (cdr (assoc 51 dxfdata)))
            (setq len (* r (abs (- ang-end ang-start))))
            (setq m 24.0)
            (while (> (/ len m plotscale) 0.2);while1--plot length of every vertice <= 0.2mm
               (setq m (+ m 12.0))
            );while1
            (setq elist (list (cons 0 "LWPOLYLINE")
                              (cons 100 "AcDbEntity")
                              (cons 100 "AcDbPolyline")
                              (cons 43 0.0)
                              (cons 90 (fix m))
                              (cons 70 0)
                              (cons 8 layer)
            );setq
            (if color (setq elist (append elist (list (cons 62 color)))))
            (if linetype (setq elist (append elist (list (cons 6 linetype)))))
            (if ltscale (setq elist (append elist (list (cons 48 ltscale)))))
            (if lineweight (setq elist (append elist (list (cons 370 lineweight)))))
            (setq n 0)
            (repeat (+ (fix m) 1) ;repeat2
               (setq ang (- ang-end ang-start))
               (if (< ang 0.0)(setq ang (+ ang (* 2.0 pi))))
               (setq pt-start (polar (cdr (assoc 10 dxfdata)) (+ ang-start (/ (* (abs ang) n) m)) r))
               (setq elist (append elist (list (list 10 x-end y-end))))
               (setq n (+ n 1))
            );repeat2
            (entmake elist)
            (entdel ssn)
         );progn1
      );if1
      (if (= "CIRCLE" (cdr (assoc 0 dxfdata)));if1
         (progn;1
            (setq len (* 2.0 pi r))
            (setq m 24.0)
               (setq m (+ m 24.0))
            );while1
                              (cons 43 0.0)
                              (cons 90 (fix m))
                              (cons 70 1)
                              (cons 8 layer)
            );setq
            (setq n 0)
            (repeat (fix m) ;repeat2
               (setq pt-start (polar (cdr (assoc 10 dxfdata)) (/ (* pi 2.0 n) m) r))
               (setq n (+ n 1))
            );repeat2
            (entmake elist)
            (entdel ssn)
         );progn1
      );if1
      (if (= "LWPOLYLINE" (cdr (assoc 0 dxfdata)));if1
         (progn;1
            (setq n-vertex (cdr (assoc 90 dxfdata)))
            (setq ifclose (cdr (assoc 70 dxfdata)))
            (setq width-fixed (cdr (assoc 43 dxfdata)))
            (setq n-vertex-end n-vertex)
            (setq elist '())
            (setq pt1 (cdr (assoc 10 dxfdata)))
            (setq pt-start-pl pt1)
            (setq dxfdata (cdr (member (assoc 10 dxfdata) dxfdata)))
            (setq x-start (car pt1) y-start (cadr pt1))
            (repeat (- n-vertex 1);1
               (if (and (= (cdr (assoc 42 dxfdata)) 0)(/= (assoc 10 dxfdata) nil));if2
                  (progn;2
                     (setq elist (append elist (list (assoc 40 dxfdata))))
                     (setq elist (append elist (list (assoc 41 dxfdata))))
                  );progn2
               );if2
               (if (and (/= (cdr (assoc 42 dxfdata)) 0)(/= (assoc 10 dxfdata) nil));if3
                  (progn;3
                     (setq width-start (cdr (assoc 40 dxfdata)))
                     (setq width-end   (cdr (assoc 41 dxfdata)))
                     (setq pt2 (cdr (assoc 10 dxfdata)))
                     (setq b (abs (cdr (assoc 42 dxfdata))))
                     (setq d (distance pt1 pt2))
                     (setq r (abs (/ (* d (+ 1.0 (* b b)))(* 4.0 b))))
                     (if (> (cdr (assoc 42 dxfdata)) 0.0)
                        (progn
                           (setq ang1 (- (- (angle pt1 pt2) (* 2.0 (atan b))) (/ pi 2.0)))
                           (setq ang2 (+ ang1 (* 4.0 (atan b))))
                           (setq pt-cen (polar pt1 (- ang1 pi) r))
                           (setq ang (- ang2 ang1))
                           (if (< ang 0.0)(setq ang (+ (* pi 2.0) ang)))
                      (if (< (cdr (assoc 42 dxfdata)) 0.0)
                         (progn
                            (setq ang2 (- (- (angle pt2 pt1) (* 2.0 (atan b))) (/ pi 2.0)))
                            (setq ang1 (+ ang2 (* 4.0 (atan b))))
                            (setq pt-cen (polar pt2 (- ang2 pi) r))
                            (if (> ang 0.0)(setq ang (- ang (* pi 2.0))))
                      (setq pt1 pt2)
                      (setq len (* r (abs ang)))
                      (setq m 24.0)
                         (setq m (+ m 12.0))
                      );while1
                      (setq n-vertex-end (+ (fix m)  n-vertex-end))
                      (setq width-step (/ (- width-end width-start) m))
                      (setq n 0)
                      (repeat (fix m);2
                         (setq elist (append elist (list (cons 40 (+ width-start (* n width-step))))))
                         (setq elist (append elist (list (cons 41 (+ width-start (* (+ 1 n) width-step))))))
                         (setq pt-start (polar pt-cen (+ ang1 (/ (* ang (+ 1 n)) m)) r))
                         (setq n (+ n 1))
                      );repeat2
                  );progn3
               );if3
            );repeat1
            (if (= (cdr (assoc 42 dxfdata)) 0.0)
               (progn
                  (setq n-vertex (- n-vertex 1))
            (if (and (/= (cdr (assoc 42 dxfdata)) 0.0) (= ifclose 1));if4
                  (progn;4
                     (setq pt2 pt-start-pl)
                        (progn
                         (progn
                      (setq m 24.0)
                         (setq m (+ m 12.0))
                      );while1
                      (setq n 0)
                      (repeat (fix m);2
                         (setq n (+ n 1))
                      );repeat2
                   );progn4
               );if4
            (setq headerlist (list (cons 0 "LWPOLYLINE")
                                   (cons 90 n-vertex-end)
                                   (cons 70 ifclose)
                                   (cons 8 layer)
            );setq
            (if width-fixed (setq headerlist (append headerlist (list (cons 43 width-fixed)))))
            (if color    (setq headerlist (append headerlist (list (cons 62 color)))))
            (if linetype (setq headerlist (append headerlist (list (cons 6 linetype)))))
            (if ltscale  (setq headerlist (append headerlist (list (cons 48 ltscale)))))
            (if lineweight (setq headerlist (append headerlist (list (cons 370 lineweight)))))
            (setq elist (append headerlist elist))
            (entmake elist)
            (entdel ssn)
         );progn1
      );if1
      (if (or(=  "TEXT" (cdr (assoc 0 dxfdata)))(=  "INSERT" (cdr (assoc 0 dxfdata))));if1
         (progn;1
               (setvar "cmdecho" 0)
               (setq oldosmode (getvar "osmode"))
               (setvar "osmode" 0)
               (setq oldautosnap (getvar "autosnap"))
               (setvar "autosnap" 0)
               (setq ang1 (cdr (assoc 50 dxfdata)))
               (setq pt-dummy (polar pt-start ang1 1.0))
               (setq x-dummy (car pt-dummy) y-dummy (cadr pt-dummy))
               (setq x-end-dummy (+ x-dummy (/ (- y-dummy y-base) (sqrt 2.0))))
               (setq y-end-dummy (+ y-base  (/ (- y-dummy y-base) (sqrt 2.0))))
               (setq ang2 (angle (list x-end y-end)(list x-end-dummy y-end-dummy)))
               (command "move"   ssn  "" pt-start (list x-end y-end 0.0))
               (command "rotate" ssn  "" (list x-end y-end 0.0)(/ (* (- ang2 ang1) 180.0) pi))
               (setvar "osmode" oldosmode)
               (setvar "autosnap" oldautosnap)
         );progn1
      );if1
      (if (or(=  "RAY" (cdr (assoc 0 dxfdata)))(=  "XLINE" (cdr (assoc 0 dxfdata))));if1
         (progn;1
                  (setq pt-dummy (cdr (assoc 11 dxfdata)))
               (setq x-dummy (+ (car pt-dummy) x-start) y-dummy (+ (cadr pt-dummy) y-start))
               (setq ang (angle (list x-end y-end)(list x-end-dummy y-end-dummy)))
                                          (- (car  (polar (list x-end y-end) ang 1.0)) x-end)
                                          (- (cadr (polar (list x-end y-end) ang 1.0)) y-end)
               (entmod dxfdata)
         );progn1
      );if1
      (if (= "SOLID" (cdr (assoc 0 dxfdata)));if1
         (progn;1
            (setq n 0)
            (repeat 4
               (setq pt-start (cdr (assoc (+ 10 n) dxfdata)))
               (setq dxfdata (subst (list (+ 10 n) x-end y-end) (assoc (+ 10 n) dxfdata) dxfdata))
               (setq n (+ n 1))
            (entmod dxfdata)
         );progn1
      );if1
      (setq i (+ i 1))
   );repeat0
   (command "undo" "end")
   (princ)
);defun[/php]
发表于 2004-6-4 17:16:50 | 显示全部楼层
祝賀wkai  升班竹了!  8-)
发表于 2004-6-4 17:29:47 | 显示全部楼层
谢谢LUCAS老兄,希望以后多多支持!
to nuance:
欢迎以后多来交流。
发表于 2004-6-4 23:28:36 | 显示全部楼层
谢谢!很好用,可有时出现下列提示,不知是怎么回事?另外,能不能也转换POLYLINE?
命令: pts
选择对象: c
指定第一个角点: 指定对角点: 找到 42 个
选择对象:
base point:; 错误: DXF 组不正确: (48)
 楼主| 发表于 2004-6-5 00:08:23 | 显示全部楼层
请楼上说明转换什么实体时出错.
得到一个积分真的很难,提供的程序用了我一周的时间,
发表于 2004-6-5 07:47:25 | 显示全部楼层
转换LWPOLYLINE时出错,如果需要我可以把图发给你。
另外,每次要输入出图比例是否有必要?
 楼主| 发表于 2004-6-5 20:24:02 | 显示全部楼层
把你的图发上来吧,lwpolyline形式太多,也许有没考虑到的情况.
出图比例只要按一次回车就行了,也不麻烦,
我的本意是控制精度,如果把分段数设为一个固定值,不是太好掌握,
数太小,弧线较长时,整体效果不好,若是数太大,弧线很短时,没必要,会影响运行速度,
我看可以这样,如果份数大于一定值,譬如200,则只分200份.
对了,楼上可以自己改程序啊.
发表于 2004-6-5 21:55:46 | 显示全部楼层
我把图发上来,见附件。
 楼主| 发表于 2004-6-5 23:05:56 | 显示全部楼层
已经改正,请重新下载附件.
发表于 2004-6-6 11:03:29 | 显示全部楼层
谢谢!已经可以用了。如发现问题再请教。
GMT+8, 2026-11-3 21:00 , Processed in 0.749464 second(s), 50 queries , Gzip On.
