查看: 691|回复: 0
[文章]:3d弹簧编程例子!!!
发表于 2004-6-7 00:50:20 | 显示全部楼层 |阅读模式
(defun myerror (s)                    ; If an error (such as CTRL-C) occurs
                                      ; while this command is active...
  (if (/= s "Function cancelled")
    (princ (strcat "\nError: " s))
  (setvar "cmdecho" ocmd)             ; Restore saved modes
  (setvar "blipmode" oblp)
  (setq *error* olderr)               ; Restore old *error* handler
  (princ)
(defun cspiral (ntimes bpoint hfac lppass strad vfac
                / ang dist tp ainc dhinc dvinc circle dv)
  (setvar "blipmode" 0)               ; turn blipmode off
  (setvar "cmdecho" 0)                ; turn cmdecho off
  (setq circle (* 3.141596235 2))
  (setq ainc (/ circle lppass))
  (setq dhinc (/ hfac lppass))
  (if vfac (setq dvinc (/ vfac lppass)))
  (setq ang 0.0)
  (if vfac
    (setq dist strad dv 0.0)
    (setq dist 0.0)
  (if vfac
    (command "3dpoly")                ; start spiral ...
    (command "pline" bpoint)          ; start spiral from base point and...
  (repeat ntimes
    (repeat lppass
      (setq tp (polar bpoint (setq ang (+ ang ainc))
                      (setq dist (+ dist dhinc))
      (if vfac
          (setq tp (list (car tp) (cadr tp) (+ dv (caddr tp)))
                dv (+ dv dvinc)
      (command tp)                    ; continue to the next point...
  (command "")                        ; until done.
  (princ)
;;;       Interactive spiral generation
(defun C:SPIRAL (/ olderr ocmd oblp nt bp cf lp)
  ;;;;(setq olderr  *error*
  ;;;;      *error* myerror)
  (setq ocmd (getvar "cmdecho"))
  (setq oblp (getvar "blipmode"))
  (initget 1)                         ; bp must not be null
  (setq bp (getpoint "\nCenter point: "))
  (initget 7)                         ; nt must not be zero, neg, or null
  (setq nt (getint "\nNumber of rotations: "))
  (initget 3)                         ; cf must not be zero, or null
  (setq cf (getdist "\nGrowth per rotation: "))
  (initget 6)                         ; lp must not be zero or neg
  (setq lp (getint "\nPoints per rotation <30>: "))
  (cond ((null lp) (setq lp 30)))
  (cspiral nt bp cf lp nil nil)
  (princ)
(defun C:3DSPIRAL (/ olderr ocmd oblp nt bp hg vg sr lp)
  (initget 7)                         ; sr must not be zero, neg, or null
  (setq sr (getdist bp "\nStarting radius: "))
  (initget 1)                         ; cf must not be zero, or null
  (setq hg (getdist "\nHorizontal growth per rotation: "))
  (setq vg (getdist "\nVertical growth per rotation: "))
  (cspiral nt bp hg lp sr vg)
  (princ)
(princ "\n\tC:SPIRAL and C:3DSPIRAL loaded. ")
(princ)
GMT+8, 2026-11-4 22:53 , Processed in 1.787737 second(s), 32 queries , Gzip On.
