查看: 2243|回复: 2
[ARX函数]:AcDbRegion:getAreaProp返回的AREA和Centroid值均为0,何故?
发表于 2004-7-22 23:35:14 | 显示全部楼层 |阅读模式
请问各位高手:下面AcDbRegion:getAreaProp返回的AREA和Centroid值均为0
ads_name en;
    ads_point pt;
        AcDbObjectId eId;
        AcDbRegion *region;
   const AcGePoint3d o;
   const AcGeVector3d x;
   const AcGeVector3d y;
   double perimeter;
   double area,a;
   AcGePoint2d centroid;
   double momInertia[2];
   double prodInertia;
   double prinMoments[2];
   AcGeVector2d prinAxes[2];
   double radiiGyration[2];
   AcGePoint2d extentsLow;
   AcGePoint2d extentsHigh;
    if(acedEntSel("\nSelect an entity: ", en, pt)==RTNORM)
     acdbGetObjectId(eId, en);
     acdbOpenObject(region, eId, AcDb::kForRead);
region->getAreaProp(o,x,y,perimeter,area,centroid,momInertia,prodInertia,prinMoments,prinAxes,radiiGyration,extentsLow,extentsHigh);
     acutPrintf("\nVertex %10.5f location is: %10.5f, %10.5f", area, centroid [0], centroid [1]);
发表于 2004-7-26 12:28:31 | 显示全部楼层
我热切期望,我刚学ARX,希望能多看到些源代码
发表于 2018-11-5 17:20:55 | 显示全部楼层
How to use AcDbRegion::getAreaProp()
By Xiaodong Liang
The first three parameters for the function are described as
- origin Returns origin of the region
- xAxis Returns xAxis of the region
- yAxis Returns yAxis of the region
But considering the const declaration for these parameters
virtual Acad::ErrorStatus getAreaProp(
                           const AcGePoint3d& origin,
                           const AcGeVector3d& xAxis,
                           const AcGeVector3d& yAxis, ... );
It's clear that these three parameters are not output parameters but input parameters. Using parameters that were not initialized properly results in the function returning Acad::eInvalidInput.
Here is a correct application of AcDbRegion::getAreaProp():
// note for code brevity, some error checking are omitted
void getRegionAreaProp()
    ads_name eNam;
    ads_point pt;
    AcDbObjectId eId;
    if (acedEntSel(L"\nSelect an region: ", eNam, pt) != RTNORM)
        acutPrintf(L"\nNothing selected.");
        return;
    acdbGetObjectId(eId, eNam);
    AcDbEntity* pEnt = NULL;
    if(acdbOpenAcDbEntity(pEnt, eId, AcDb::kForRead) != Acad::eOk)
        acutPrintf(L"\nError open entity.");
        return;
    AcDbRegion* pReg = AcDbRegion::cast(pEnt);
    if(!pReg)
        pEnt->close();
        return;
    double perimeter, area, momInertia[2],
           prodInertia, prinMoments[2],
           radiiGyration[2];
    AcGePoint2d centroid, extentsLow, extentsHigh;
    AcGePoint3d origin;
    AcGeVector3d xAxis;
    AcGeVector3d yAxis;
    // initialize the three arguments
    AcGePlane plane;
    pReg->getPlane(plane);
    plane.getCoordSystem(origin, xAxis, yAxis);
    Acad::ErrorStatus es = pReg->getAreaProp(
        // these (3) are the input parameters
        origin, xAxis, yAxis,
        perimeter,
        area,
        centroid,
        momInertia,
        prodInertia,
        prinMoments,
        prinAxes,
        radiiGyration,
        extentsLow,
        extentsHigh);
    assert(es == Acad::eOk);
    // you can determine what to do exactly with the results
    // here I just print a message
    acutPrintf(L"\nSucceded in getting an region's area prop.");
    pReg->close();
评分
参与人数 1D豆 +10 收起 理由
XDSoft + 10 很给力!经验;技术要点;资料分享奖!
查看全部评分
GMT+8, 2026-11-22 10:59 , Processed in 0.305313 second(s), 15 queries , Gzip On, File On.
