查看: 1022|回复: 3
[LISP程序]:标注粗糙度的程序(原作小妹丁)
发表于 2004-11-20 16:54:46 | 显示全部楼层 |阅读模式
原作为小妹丁的,我对程序改了一下,希望大家多提意见
[php]
;;;一个新的粗糙度标注方式
;;;2004.10.06
;;;2004.11.16更改,更改人:hyx_lyn
(defun c:cud ()
  (defun myerror (msg)
    (setvar "osmode" os)                ;恢复捕捉
    (setq *error* olderr)                ;恢复原来的出错函数
    (princ)
  (setq        olderr        *error*                        ;保存旧的
        *error*        myerror                        ;设置新的
  (princ "可在空白处标注")
  (setq osm (getvar "osmode"))
  (setq cmd (getvar "cmdecho"))
  (setq dims (getvar "dimscale"))
  (setq h (getvar "dimtxt"))
  (setvar "cmdecho" 0)
  (setvar "osmode" 0)
  (vl-cmdf ".undo" "be")                ;设置后退的起始点
  (setq en (nentsel))
  (if en
    (progn
      (setq pt (osnap (cadr en) "nea"))
      (setq endata (entget (car en)))
      (setq xxob (cdr (assoc 0 endata)))
      (cond ((= xxob "LINE")                ;实体为LINE
             (culine pt endata)
            ((or (= xxob "ARC") (= xxob "CIRCLE")) ;实体为ARC or CIRCLE
             (cuarc pt endata)
            ((= xxob "LWPOLYLINE")        ;实体为LWPOLYLINE
             (vl-cmdf "explode" en)
             (setq enn (ssname (ssget pt) 0))
             (setq endata (entget enn))
             (culine pt endata)
            (t (alert "对不起,暂未支持该实体类型。"))
    (progn                                ;未选取实体时,在空白处标注
      (setq pt (getpoint "在空白处确认标注位置:"))
      (setq pt-0 (polar pt (/ pi 2) 10))
      (SETQ ang (ANGLE pt pt-0))
      (setq bx (getreal "\n粗糙度(非加工 0)<12.5>:"))
      (IF (= bx NIL)
        (SETQ bx 12.5)
      (if (= bx 0)                        ;非加工标注
        (progn
          (SETQ cud_pt1 (POLAR pt (- ang (cud_dtr 30)) (* 3.0 h)))
          (SETQ cud_pt2 (POLAR pt ang (* 1.0 h)))
          (SETQ cud_pt3 (POLAR pt (+ ang (cud_dtr 30)) (* 1.5 h)))
          (vl-cmdf "PLINE" cud_pt3 "w" 0 "" pt cud_pt1 "")
          (vl-cmdf "circle" cud_pt2 (* 0.5 h))
        (progn
          (cud_fuhao pt ang h)
          (setq bX (rtos bX 2 1))
          (setq px0 (polar pt (* pi 0.5) (* 2.0 h)))
          (setq angle_text 0)
          (vl-cmdf "text" "m" px0 (* h 1.0) angle_text bx "")
      (setq pxt (polar cud_pt3 pi (* 2.5 h)))
      (setq bxqu "其余")
      (vl-cmdf "text" "m" pxt (* h 2.5) 0 bxqu "")
  (setvar "cmdecho" cmd)
  (setvar "osmode" osm)
  (vl-cmdf ".undo" "e")                        ;设置结束
(princ "\n***CUD.小妹丁,2004.10.23***")
(princ "\n***CUD.hyx_lyn,2004.11.20***")
(princ)
;;;实体为ARC or CIRCL
(defun cuarc (pt engata)
  (setq arc_r (cdr (assoc 40 endata)))        ;取得半径
  (setq arc_p0 (cdr (assoc 10 endata)))        ;取得圆心
  (setq ptf (getpoint pt "\n指向:"))
  (setq angle_ptf (angle arc_p0 pt))
  (setq dis_ptf (distance arc_p0 ptf))
  (if (> dis_ptf arc_r)
    (progn
      (cud_fuhao pt angle_ptf h)
      (setq px0 (polar pt angle_ptf (* 2.0 h)))
      (setq angle_text (cud_rtd (+ (/ pi 2) angle_ptf)))
      (if (and (>= angle_ptf 0) (<= angle_ptf pi))
        (setq angle_text (+ 180 angle_text))
      (setq bx (getREAL "\n粗糙度<3.2>:"))
      (IF (= bx NIL)
        (SETQ bx 3.2)
    (progn
      (cud_fuhao pt (+ angle_ptf pi) h)
      (setq px0 (polar pt (+ angle_ptf pi) (* 2.0 h)))
      (IF (= bx NIL)
        (SETQ bx 3.2)
;;;实体为LINE LWPOLYLINE
(defun culine (pt endata)
  (setq pl1 (cdr (assoc 10 endata)))
  (setq pl2 (cdr (assoc 11 endata)))
  (setq langle12 (angle pl1 pl2))
  (setq langle21 (angle pl2 pl1))
  (if (> langle12 langle21)
    (setq angle_line
           langle21
          pl1 pl2
    (setq angle_line langle12)
  (setq angle_text (cud_rtd angle_line))
  (if (> angle_text 90)
    (setq angle_text (- angle_text 180))
  (setq angle_ptf (angle pl1 ptf))
  (if (and (> angle_ptf angle_line)
           (< angle_ptf (+ angle_line pi))
    (progn
      (cud_fuhao pt (+ (/ pi 2) angle_line) h)
      (setq px0 (polar pt (+ angle_line (/ pi 2)) (* 2.0 h)))
      (IF (= bx NIL)
        (SETQ bx 3.2)
    (progn
      (cud_fuhao pt (- angle_line (/ pi 2)) h)
      (setq px0 (polar pt (- angle_line (/ pi 2)) (* 2.0 h)))
      (IF (= bx NIL)
        (SETQ bx 3.2)
(defun cud_fuhao (IP IRA cud_k)
  (SETQ cud_pt1 (POLAR IP (- IRA (cud_dtr 30)) (* 3.0 cud_k)))
  (SETQ cud_pt2 (POLAR IP (- IRA (cud_dtr 30)) (* 1.5 cud_k)))
  (SETQ cud_pt3 (POLAR IP (+ IRA (cud_dtr 30)) (* 1.5 cud_k)))
  (vl-cmdf "PLINE" cud_pt2 "w" 0 "" cud_pt3 IP cud_pt1 "")
(DEFUN cud_dtr (A)
  (* PI (/ A 180.0))
(DEFUN cud_rtd (A)
  (* 180.0 (/ A pi))
[/php]
发表于 2004-11-21 10:40:03 | 显示全部楼层
来个简单点的:
[PHP]
(defun c:test ()
  (setvar "osmode" 0)
  (setq p0 (getpoint "\nInput point"))
  (setq high (* (getvar "dimscale")(getvar "dimtxt")))
  (setq p1 (osnap p0 "near"))
  (if p1 (setq ang (angle p1 p0))(setq ang (/ pi 2) p1 p0))
  (if (or (null cvalue)(= cvalue ""))(setq cvalue "32"))
  (princ "\nInput Crudity Value <")
  (princ cvalue)
  (princ ">")
  (setq string (getstring))
  (if (or (null string)(= string ""))(setq string cvalue)(setq cvalue string))
  ;(mlayer "dim" "blue" "continuous")
  (vl-cmdf "pline" (polar p1 (- ang (/ pi 6))(/ high 0.3)) p1
                   (polar p1 (+ ang (/ pi 6))(/ high 0.6))
                   (Polar p1 (- ang (/ pi 6)) (/ high 0.6)) "")
  (if (and (< ang (/ (* pi 6) 7))(> ang (/ pi 6)))
    (setq d 1 p0 (polar p1 ang (/ high 0.55)))
    (setq d -1 p0 (polar p1 ang (/ high 0.35)))
  (vl-cmdf "text" "j" "f" (polar p0 (+ ang (* d (/ pi 2))) high)
                          (polar p0 (- ang (* d (/ pi 2))) high) high string)
[/PHP]
发表于 2004-11-22 00:43:04 | 显示全部楼层
楼主让我出丑了,不过你改造得更好。
我的LISP学得好烂,凑合自己玩下,现在也没时间碰了。
我记得发的是FAS文件,你也解得出,厉害。
 楼主| 发表于 2004-11-22 08:12:59 | 显示全部楼层
小妹丁你好:
    你记错了,你发的是LISP文件。因为现在画图需要标注粗糙度所以前些日子在论坛中搜到的,用了一下觉得不错,只是有一些地方不太适合,所以未经你同意就改了一下,目的只是让我们作的更好而以。
GMT+8, 2026-11-5 10:56 , Processed in 0.508702 second(s), 38 queries , Gzip On.
