查看: 1499|回复: 7
[求助] [求助]:autolisp 程序 不能运行
发表于 2004-12-1 13:23:48 | 显示全部楼层 |阅读模式
以下是在一文本周围加一边框,是从一教学网站上下载的,但不能运行,请指教!
(DEFUN C:TEXT_F ( ) (SETQ OBJ (ENTSEL "\nSelect Text : "))
(IF (= OBJ NIL) (PRINC "\nNone Object Select") (PROGN
(SETQ ENT (ENTGET (CAR OBJ)))
(IF (/= CDR (ASSOC 0 ENT)) "TEXT")
(PRINC "\nObject Type Error") (PROGN
(SETQ TEMP (CADR (TEXTBOX (LIST (ASSOC 1 ENT))))
TEMP_W (CAR TEMP) TEMP_H (CADR TEMP)
PT_BASE (CDR (ASSOC 10 ENT)))
(COMMAND "PLINE" PT_BASE
(SETQ PT_TEMP (POLAR PT_BASE 0 TEMP_W))
(SETQ PT_TEMP (POLAR PT_TEMP (/ PI 2) TEMP_H))
(SETQ PT_TEMP (POLAR PT_TEMP PI TEMP_W)) "C")
(PRINC))
发表于 2004-12-1 13:59:29 | 显示全部楼层
[php]
(DEFUN C:TEXT_F        ()
  (IF (= OBJ NIL)
    (PROGN
        "TEXT"
      (PROGN
              TEMP_W  (CAR TEMP)
              TEMP_H  (CADR TEMP)
        (COMMAND "PLINE"
                 PT_BASE
                 "C"
(PRINC)
[/php]
已领礼包: 488个
发表于 2004-12-2 00:49:16 | 显示全部楼层
哪个教学网站骗人呀!
cad的帮助里有实例,Visual LISP Tutorial 里面.
或者其他地方,你找找,肯定有.
 楼主| 发表于 2004-12-2 10:08:16 | 显示全部楼层
谢谢!
已领礼包: 12490个
发表于 2004-12-2 10:48:16 | 显示全部楼层
程序有误,不支持字宽比例和文字倾角。
程序更改后如下:
[php]
(DEFUN C:TEXT_F ()
(IF (/= OBJ nil) (PROGN
  (IF (= (CDR (ASSOC 0 ENT)) "TEXT") (PROGN
         ANG     (CDR (ASSOC 50 ENT))
         TEXTW   (CDR (ASSOC 41 ENT))
         TEMP_W  (* (CAR TEMP) TEXTW)
         TEMP_H  (CADR TEMP))
         (SETQ PT_TEMP (POLAR PT_BASE ANG TEMP_W))
         (POLAR PT_TEMP (+ (/ PI 2) ANG) TEMP_H)
         (POLAR PT_BASE (+ (/ PI 2) ANG) TEMP_H)
         "C"
(PRINC)
[/php]
发表于 2004-12-2 10:55:19 | 显示全部楼层
同样功能且可批处理:
[PHP]
(defun c:test ()
  (setq ss (ssget '((0 . "*TEXT"))) n 0)
  (while (< n (sslength ss))
    (setq b (acet-geom-extents (ssname ss n)))
    (vl-cmdf "rectang" (car b)(cadr b))
    (setq n (1+ n))
[/PHP]
发表于 2004-12-2 11:52:47 | 显示全部楼层
能不能解释一下
已领礼包: 488个
发表于 2004-12-2 23:48:06 | 显示全部楼层
最初由 lsjjm 发布
[B]同样功能且可批处理:
[PHP]
(defun c:test ()
    (vl-cmdf "rectang" (car b)(ca... [/B]
有角度怎么办?
能不能解释一下
相当于把文字移动到原点,再转成0度,这时的textbox就可以画框了,完了,一起还原到原来的状态.
GMT+8, 2026-11-5 15:30 , Processed in 0.403533 second(s), 46 queries , Gzip On.
