查看: 648|回复: 0
[分享]:试试你的电脑怎么样!
发表于 2005-1-3 11:58:15 | 显示全部楼层 |阅读模式
(defun c:test ()
    (setq p (getpoint "Where? "))
    (setq p (trans p 1 0 ))
    (setq xp (car p))
    (setq yp (cadr p))
    (setq se 2)
    (setq jiaoa 0)
    (setq yan 0 )
   (while (<= jiaoa 90)
    (setq x (* (cos jiaoa ) 5))
    (setq y (* (sin jiaoa ) 5))
    (setq x (+ x xp))
    (setq y (+ y yp))
    (setq zhongxin (list 10 x y ))
    (setq yan (+ 1 yan ))
    (if (= yan 250) (setq yan 0))
    (setq yanse (cons 62 yan))
    (setq c (list '(0 . "CIRCLE") yanse zhongxin '(40 . 1.0)))
    (entmake c)
    (setq jiaoa (+ jiaoa  0.0005)) ;;修改0.0005
我的电脑只能到0.0005了,就快死机了,平移不动了,你们的电脑能再改小吗?
P4 2.4 512MDDR
GMT+8, 2026-11-5 21:28 , Processed in 0.382649 second(s), 32 queries , Gzip On.
