查看: 959|回复: 3
[ARX程序]:派生于AcDbObject的定制类实体加入到对象字典的问题??
发表于 2005-1-10 00:11:57 | 显示全部楼层 |阅读模式
我自己写了一个类要加入字典中,但调不通,请高手指点。。。
下面是代码:
// ScaleClass.h: interface for the CScaleClass class.
#if !defined(AFX_SCALECLASS_H__EA5D03B9_CC89_40B1_8BB4_48EB14A3EF04__INCLUDED_)
#define AFX_SCALECLASS_H__EA5D03B9_CC89_40B1_8BB4_48EB14A3EF04__INCLUDED_
#if _MSC_VER > 1000
#pragma once
#endif // _MSC_VER > 1000
class CScaleClass : public AcDbObject
public:
void setvScale(double vs);
void sethScale(double hs);
void getvScale(double hv);
void gethScale(double hs);
double vScale;
double hScale;
CScaleClass();
virtual ~CScaleClass();
#endif // !defined(AFX_SCALECLASS_H__EA5D03B9_CC89_40B1_8BB4_48EB14A3EF04__INCLUDED_)
// ScaleClass.cpp: implementation of the CScaleClass class.
#include "stdafx.h"
#include "resource.h"
#include "ScaleClass.h"
#ifdef _DEBUG
#undef THIS_FILE
static char THIS_FILE[]=__FILE__;
#define new DEBUG_NEW
#endif
// Construction/Destruction
CScaleClass::CScaleClass()
CScaleClass::rxInit();
CScaleClass::~CScaleClass()
void CScaleClass::gethScale(double hs)
hs=hScale;
return;
void CScaleClass::getvScale(double hv)
hv=vScale;
return;
void CScaleClass::sethScale(double hs)
hScale=hs;
return;
void CScaleClass::setvScale(double vs)
vScale=vs;
return;
下面是加入程序
void GeoMapFun::createDictionary(double hs, double vs)
    AcDbDictionary *pNamedobj;
    acdbHostApplicationServices()->workingDatabase()->
        getNamedObjectsDictionary(pNamedobj, AcDb::kForWrite);
    // Check to see if the dictionary we want to create is
    // already present. If not, create it and add
    // it to the named object dictionary.
    AcDbDictionary *pDict;
    if (pNamedobj->getAt("SCALE_DICT", (AcDbObject*&) pDict,
        AcDb::kForWrite) == Acad::eKeyNotFound)
        pDict = new AcDbDictionary;
        AcDbObjectId DictId;
        pNamedobj->setAt("ASDK_DICT", pDict, DictId);
    pNamedobj->close();
    if (pDict) {
        // Create new objects to add to the new dictionary,
        // add them, then close them.
        CScaleClass *pObj1 = new CScaleClass();
  pObj1->sethScale(hs);
  pObj1->setvScale(vs);
        AcDbObjectId rId1;
        pDict->setAt("OBJ1", pObj1, rId1);
        pObj1->close();
        pDict->close();
void GeoMapFun::iterateDictionary(double hs, double vs)
        ->getNamedObjectsDictionary(pNamedobj, AcDb::kForRead);
    // Get a pointer to the ASDK_DICT dictionary.
    pNamedobj->getAt("SCALE_DICT", (AcDbObject*&)pDict,
        AcDb::kForRead);
    pNamedobj->close();
    // Get an iterator for the ASDK_DICT dictionary.
    AcDbDictionaryIterator* pDictIter= pDict->newIterator();
    CScaleClass *pMyCl;
    for (; !pDictIter->done(); pDictIter->next()) {
        // Get the current record, open it for read, and
        // print its data.
        pDictIter->getObject((AcDbObject*&)pMyCl,
            AcDb::kForRead);
        pMyCl->gethScale(hs);
  pMyCl->getvScale(vs);
        pMyCl->close();
        acutPrintf("\nintval is:  %d", hs);
    delete pDictIter;
    pDict->close();
请高手指点,谢谢!!
发表于 2005-1-10 21:45:19 | 显示全部楼层
一个编译过的例子.没有运行过,以后请把工程贴上来,因为整理很费时间
 楼主| 发表于 2005-1-11 18:57:22 | 显示全部楼层
我按照你的程序,已经调好了,!
以后有问题一定贴工程.
发表于 2006-11-8 15:15:49 | 显示全部楼层
老兄,就这么简单吗?非图形特征数据直接利用object派生对象往命名词典里加?
GMT+8, 2026-11-3 03:12 , Processed in 0.531679 second(s), 39 queries , Gzip On.
