查看: 838|回复: 0
[教学]:MDL 初学者进来看看 也来一个例子
发表于 2003-3-19 09:30:45 | 显示全部楼层 |阅读模式
#include    <mdl.h>            /* system include files */
#include    <global.h>
#include    <mselems.h>
#include    <tcb.h>
#include    <stdio.h>
#define  UOR   (tcb->subpermast*tcb->uorpersub*1.0)
int linestrg_firstPoint(Dpoint3d *pt)
  int level,color,weight;
  char str[20];
  MSElement el;
  Dpoint3d points[2];
  double dist=60;
  strcpy(str,"字符串");
  mdlText_create(&el,NULL,str,pt,NULL,NULL,NULL,NULL);  /*建立一个字符串元素*/
  mdlElement_add(&el);                     /*写入DGN文件中*/
  mdlElement_display(&el,0);                 /*将元素显示出来*/
  points[0]=points[1]=*pt;
  points[1].x=points[1].x+100*UOR;
  mdlParams_setActive (1, ACTIVEPARAM_LINESTYLE);    /*设置当前画线线形*/
  level=10;
  mdlParams_setActive (level, ACTIVEPARAM_LEVEL);   /*设置当前层*/
  mdlLine_create(&el,NULL,points);          /*建立一个线元素*/
  color=100; weight=1;
  mdlElement_setSymbology(&el,&color,&weight,NULL);          /*改变元素 的颜色和线宽*/
  mdlSystem_exit(0,1);  /*退出程序*/
void  main
int        argc,
char        *argv[]
  mdlState_startPrimitive (linestrg_firstPoint, 0, 0,  0); /*等待输入一个点---按鼠标左键*/
  mdlOutput_error("输入一个点 ");
GMT+8, 2026-11-2 22:15 , Processed in 0.491849 second(s), 30 queries , Gzip On.
