查看: 798|回复: 2
[求助]:AcDb2dPolyline的elevation 参数怎么理解?
发表于 2005-8-31 01:03:09 | 显示全部楼层 |阅读模式
AcDb2dPolyline(
AcDb::Poly2dType type,
AcGePoint3dArray& vertices,
double elevation = 0,
Adesk::Boolean closed = Adesk::kFalse,
double defStartWidth = 0,
double defEndWidth = 0,
AcGeDoubleArray* bulges = NULL);
高度?
发表于 2005-8-31 11:58:10 | 显示全部楼层
这个多义线是2d的,那么所有点在同一个高度上,这里的elevation就是把多义线放在哪个高度上,
默认值是0.0
 楼主| 发表于 2005-8-31 13:17:01 | 显示全部楼层
就是说3d的没有线宽?
GMT+8, 2026-11-5 04:06 , Processed in 0.467547 second(s), 36 queries , Gzip On.
