查看: 3595|回复: 11
[LISP函数]:判斷是否爲數字還是字符串
发表于 2005-12-13 22:56:06 | 显示全部楼层 |阅读模式
[PHP]
;;; ******* text_num_p - function ************
;;; this function must be passed a string
;;; then it returns t if the string would
;;; be a valid number or nil if it would not
(defun text-nump (string /               ; passed to function
                            cnt               ; temporary counter
                            cc               ; current charcter to be tested
                            allnum     ; t = number,  nil = not number
                            numdec     ; number of decmials found
                            test       ; test varaible
  (setq cnt 1
        allnum t
  (setq cc (substr string cnt 1))      ; loop to test each charcter
  (while (and
           cc
           allnum
         )                               ; test to see what current
                                       ; charcter is
    (setq test (cond
                 ((and
                    (= cnt 1)
                    (= cc "-")
                 ((= cc "1"))
                 ((= cc "2"))
                 ((= cc "3"))
                 ((= cc "4"))
                 ((= cc "5"))
                 ((= cc "6"))
                 ((= cc "7"))
                 ((= cc "8"))
                 ((= cc "9"))
                 ((= cc "0"))
                 ((= cc ".")
                   "dec"
                 (t
                   nil
               )                       ; end cond
    )                                       ; end setq
                                       ; test to see if current
                                       ; charcter is
                                       ; part of a valid number
    (cond
      ((= test nil)
        (setq allnum nil)
      ((and
         (= numdec nil)
         (= test "dec")
        (setq numdec 1)
      ((and
         (= numdec 1)
         (= test "dec")
        (setq allnum nil)
    )                                       ; end cond
                                       ; get next charcter
    (setq cnt (1+ cnt))
    (if (= cc "")
      (setq cc nil)
  )                                       ; end while
  (eval allnum)                               ; returnc t or nil
;;; end text_num_p function[/PHP]
发表于 2005-12-14 13:58:25 | 显示全部楼层
(if (distof str)
  T
nil)
字符串是数值返回T
 楼主| 发表于 2005-12-15 08:23:45 | 显示全部楼层
(defun Is-String (arg) (equal (type arg) 'str))
发表于 2006-4-12 16:45:33 | 显示全部楼层
(if (= (read str) (atof str))  T  nil)
字符串是数值返回T
 楼主| 发表于 2007-7-3 14:37:30 | 显示全部楼层
一楼与以下几个是有点不同的。
一楼是判断某字符串是由数字组成与否。(下面与一楼相同)
  1.   [FONT=courier new]
  2. (defun th2-text-nump (txt / k len n num tmp)
  3.   (setq len (strlen txt)
  4.         n 1
  5.         k 2
  6.   )
  7.   (if (= (substr txt 1 1) "-")
  8.     (while (<= k len)
  9.       (setq tmp (substr txt k 1))
  10.       (if (vl-string-search tmp "1234567890.")
  11.         (setq num t
  12.               k (1+ k)
  13.         )
  14.         (setq num nil
  15.               k (1+ len)
  16.         )
  17.       )
  18.     )
  19.     (while (<= n len)
  20.       (setq tmp (substr txt n 1))
  21.       (if (vl-string-search tmp "1234567890.")
  22.         (setq num t
  23.               n (1+ n)
  24.         )
  25.         (setq num nil
  26.               n (1+ len)
  27.         )
  28.       )
  29.     )
  30.   )
  31.   num
  32. )
  33. (defun th3-text-nump (string)
  34.   (numberp (read string))
  35. )
  36.   [/FONT]
发表于 2007-12-4 09:37:39 | 显示全部楼层
(defun zgx-singlestr-if-num (str lst)
    (if        (or
            (wcmatch str "#")
            (member str lst)
        t
        nil
;;;---判断整个单词是否为数字,lst ( "+" ".") 需要当作数字处理的符号----------
(defun zgx-wholestr-if-num (str lst / yes)
    (setq yes t)
    (while (and
               (/= "" str)
               yes
        (if (zgx-singlestr-if-num (zgx-substr str 1 1) lst)
            (setq str (zgx-substr str 2 1))
            (setq yes nil)
    yes
发表于 2008-1-23 06:07:19 | 显示全部楼层
不用这么复杂
(defun CD-STR-IF(str)(if(not (wcmatch str "*@*,*-*,#*'.*")) T nil))
_$ (CD-STR-if "12345")
T
_$ (CD-STR-if "12345a")
nil
 楼主| 发表于 2008-1-29 07:55:58 | 显示全部楼层
最初由 wwwchard 发布
[B]不用这么复杂
T
nil [/B]
  2. test
  3. 命令: (CD-STR-IF ".123")
  4. T
  5. 命令: (CD-STR-IF "1.1a23")
  6. nil
  7. 命令: (CD-STR-IF "-.123")
  8. nil
  9. 命令: (CD-STR-IF "-123")
  10. nil
  11. 命令: (CD-STR-IF "+123")
  12. T
  13.   [/FONT]
复制代码
发表于 2008-2-1 09:40:44 | 显示全部楼层
(ssget     '((0 . "TEXT") (1 . "~*[~`--9]*")) )
发表于 2008-2-9 18:10:30 | 显示全部楼层
非常不错的东西
发表于 2009-4-30 21:00:08 | 显示全部楼层
我的函数,很简单的
(type (read $***))
不用像上面这么麻烦的吧
发表于 2013-5-1 13:46:24 | 显示全部楼层
学习了,谢谢分享
GMT+8, 2026-11-22 08:37 , Processed in 0.518463 second(s), 32 queries , Gzip On, File On.
