查看: 1264|回复: 1
[求助] [求助]:请协助更新Autolisp
发表于 2006-4-15 17:05:58 | 显示全部楼层 |阅读模式
【Dtol.lsp】是拙作标注公差用之LISP。原先的upper tolerance和Lower tolerance只可输入数字(如+0.02 -0.01),祈望它也可以输入公差符号(如H7 m6),请诸位先进贤达协助更新。
Dtol.lsp
(defun c:dtol()
(setq upv(getstring "\nUpper Tolerance :"))
(setq lowerv(getstring "\nLower Tolerance :"))
(setq txth(getreal "\nTolerance Text High :"))
(if lowerv
(if (= (substr lowerv 1 1) "+")
(progn
(setq lowerv(atof lowerv))
(setq lowerv(- 0 lowerv))
(setq lowerv (abs (atof lowerv)))
(setq upv(atof upv))
(setvar "dimtfac" txth)
(setvar "dimtol" 1)
(setvar "dimalttz" 1)
(setvar "dimtp" upv)
(setvar "dimtm" lowerv)
(command "dim" "update" pause "" "exit")
(setvar "dimtol" 0)
发表于 2006-4-15 17:08:09 | 显示全部楼层
这个发到※AutoLISP/VLISP 开发技术※ 版块更好!
帮你搬个家!
GMT+8, 2026-11-22 09:39 , Processed in 0.320700 second(s), 12 queries , Gzip On, File On.
