查看: 945|回复: 1
[LISP程序]:给定两点和弦长画圆弧
发表于 2006-4-26 08:51:37 | 显示全部楼层 |阅读模式
给定两点和弦长画圆弧
  1. (defun C:TT  (/ P1 P2 DS DI A1 A2 AM RE N)
  2.   (defun MKARC_SEA  (P1 P2 ANG / E)
  3. (vl-load-com)
  4.   (command "arc" "non" P1 "e" "non" P2 "d" "non" (polar P1 (+ ANG (angle P1 P2)) 1000))
  5.   (setq E (entlast))
  6.   (list (vlax-curve-getdistatparam E (vlax-curve-getendparam E)) E))
  7.   (setq        P1 (getpoint "\圆弧起点:")
  8.         P2 (getpoint "\圆弧终点:")
  9.         DS (distance P1 P2))
  10.   (princ (strcat "\n弦长:" (rtos DS 2 4)))
  11.   (while (not (and (setq DI (getreal "\n输入弧长:")) (> DI DS)))(princ "\n无效输入!"))
  12.   (setq        A1 0        A2 3.1415926        N  0)
  13.   (while (and (setq RE (MKARC_SEA P1 P2 (setq AM (/ (+ A1 A2) 2.0))))
  14.               (not (equal DI (car RE) 1e-10)))
  15.     (if        (> (car RE) DI)
  16.       (setq A2 AM)
  17.       (setq A1 AM))
  18.     (entdel (cadr RE))
  19.     (setq N (1+ N)))
  20.   (print N)
  21.   (if (getpoint "\n反向?")(command "mirror" (cadr re) "" "non" p1 "non" p2 "y"))
  22.   (princ))
  23. (princ "\n给定两点和弦长画圆弧 by wkai from XDCAD.net")
  24. (princ "\n命令:TT")
发表于 2006-4-26 15:16:30 | 显示全部楼层
好像它山之石还是谁以前做过一个,思路大概差不多。逼近法
GMT+8, 2026-11-4 01:50 , Processed in 0.401073 second(s), 34 queries , Gzip On.
