查看: 2585|回复: 2
[求助]:咋搞定Map 3D 2007呢?
发表于 2006-8-16 07:51:38 | 显示全部楼层 |阅读模式
1. Install the software
2. After installation, copy \Crack\Map3D\adlmdll.dll to ...\Autodesk Map 3D 2007\ and overwrite the original one
3. Import Map3D.reg
4. Setup Flexlm License Server with the files in the supplied FlexLM directory.
5. Start the inventor, input 2080@your_server_host_name or just point to license.lic while the license is requested
enjoy it!
TEAM ZWT /2006
上面是破解文档说的。我安装完FlexLM后,用破解目录下的同名文件覆盖了,可压根就没法“input 2080@your_server_host_name or just point to license.lic while the license is requested”,程序一启动,就说License不行,要求重启电脑或和系统管理员联系?
机子上同时装了ACAD 2007中文版、Civil 3D 2006中文版?难不成有冲突?咋解决呢?各位大侠帮帮忙啊?!谢了!
发错地方了,版主删除了吧?俺自己怎么删除不了?
发表于 2006-11-17 17:08:38 | 显示全部楼层
你的是英文版的吧?
发表于 2024-9-20 08:25:03 | 显示全部楼层
不错,谢谢分享!!!!!
GMT+8, 2026-11-22 07:36 , Processed in 0.372877 second(s), 14 queries , Gzip On, File On.
