查看: 1389|回复: 1
[讨论]:如何设置单行文字字体
发表于 2006-12-13 19:26:11 | 显示全部楼层 |阅读模式
请教版主和各位高手
我只想对图中的个别字设置为另一种字体
我该如何设置
发表于 2006-12-24 13:50:51 | 显示全部楼层
没办法直接设置,只能通过选择集,获取其插入点\对齐点,字高,宽高比,TEXT文本内容,追加个TEXT文本,删除老的文本.   Select Case Trim(xdataOut(1))
                                Case "121211"
                                       Set newTextStyle = ThisDrawing.TextStyles.Add("细等线体")
                                       ThisDrawing.ActiveTextStyle = newTextStyle
                                      ' ThisDrawing.ActiveTextStyle.fontFile = "c:\WINDOWS\Fonts\FZXDXJW.TTF"
                                       vps1 = ent.textString
                                       vps = ent.insertionPoint
                                       vps3 = ent.Alignment
                                       vps4 = ent.TextAlignmentPoint
                                       vps(0) = vps(0) + 3
                                       vps(1) = vps(1)
                                       vps(2) = vps(2)
                                     '  ThisDrawing.ActiveTextStyle.fontFile = "FZXDXJW.TTF" '使用指定字体
                                       Set tex = ThisDrawing.ModelSpace.AddText(vps1, vps, Int(2# / 2 * 100) / 100)
                                       ent.Delete
                                       tex.Alignment = vps3
                                       tex.TextAlignmentPoint = vps4
                                       tex.height = Int(2# / 2 * 100) / 100
                                       tex.VerticalAlignment = 0 '垂直调整
                                       tex.ObliqueAngle = 0 '文本倾斜 左负 右正,取的正弦值
                                       tex.ScaleFactor = 0.8  '调整宽高比例
                                       DataType(0) = 1001: Data(0) = "SOUTH"
                                       DataType(1) = 1000: Data(1) = "121211"
                                       DataType(2) = 1003: Data(2) = "TK"
                                       tex.SetXData DataType, Data
                                Case "121205"
                                       Set newTextStyle = ThisDrawing.TextStyles.Add("等线体")
                                       ThisDrawing.ActiveTextStyle.fontFile = "c:\WINDOWS\Fonts\SIMHEI.TTF"
                                       If Right(vps1, 1) = "." Then
                                          vps4(0) = vps4(0) + 0.3
                                          vps4(1) = vps4(1) - 0.75
                                          vps4(2) = vps4(2)
                                          Set tex = ThisDrawing.ModelSpace.AddText((Right(vps1, Len(vps1) - 1)), vps, Int(3 / 2 * 100) / 100)
                                          ent.Delete
                                          DataType(1) = 1000: Data(1) = "121205"
                                        ElseIf Left(vps1, 2) = "37" And Len(vps1) = 7 Then
                                          vps1 = Right(vps1, Len(vps1) - 2)
                                          vps(0) = vps(0)
                                          vps(1) = vps(1)
                                          vps(2) = vps(2)
                                          Set tex = ThisDrawing.ModelSpace.AddText(vps1, vps, Int(3 / 2 * 100) / 100)
                                          ent.Delete
                                        Else
                                          vps(0) = vps(0)
                                          vps(1) = vps(1)
                                          vps(2) = vps(2)
                                          ent.Delete
                                        End If
                                Case "121206"
                                       ent.height = Int(3.75 / 2 * 100) / 100
                                       ent.VerticalAlignment = 0 '垂直调整
                                       ent.ObliqueAngle = 0 '文本倾斜 左负 右正,取的正弦值
                                       ent.ScaleFactor = 1 '调整宽高比例
                                       DataType(1) = 1000: Data(1) = "121206"
                                Case "121207"
                                       Set newTextStyle = ThisDrawing.TextStyles.Add("宋体")
                                       ThisDrawing.ActiveTextStyle.SetFont "宋体", False, False, 1, 1
                                       vps(0) = vps(0)
                                       vps(1) = vps(1)
                                       vps(2) = vps(2)
                                      ' ThisDrawing.ActiveTextStyle.fontFile = "SIMKAI.TTF" '使用指定字体
                                       Set tex = ThisDrawing.ModelSpace.AddText(zbxt, vps, Int(1.9 / 2 * 100) / 100)
                                       ent.Delete
                                       tex.Alignment = acAlignmentLeft
                                       tex.height = Int(1.9 / 2 * 100) / 100
                                       tex.ScaleFactor = 1.4 '调整宽高比例
                                       vps(0) = vps(0)
                                       vps(1) = vps(1) + 0.9
                                       vps(2) = vps(2)
                                       tex.insertionPoint = vps
                                       DataType(1) = 1000: Data(1) = "121207"
                                Case "121208"
                                       vps(0) = vps(0)
                                       vps(1) = vps(1)
                                       vps(2) = vps(2)
                                       Set tex = ThisDrawing.ModelSpace.AddText(gcjz, vps, Int(1.9 / 2 * 100) / 100)
                                       ent.Delete
                                       vps(0) = vps(0)
                                       vps(1) = vps(1) + 0.9 + 0.1
                                       vps(2) = vps(2)
                                       DataType(1) = 1000: Data(1) = "121208"
                                Case "121209"
                                       vps(0) = vps(0)
                                       vps(1) = vps(1)
                                       vps(2) = vps(2)
                                       Set tex = ThisDrawing.ModelSpace.AddText(dcgc, vps, Int(1.9 / 2 * 100) / 100)
                                       ent.Delete
                                       vps(0) = vps(0)
                                       vps(1) = vps(1) + 0.9 + 0.1 * 2
                                       vps(2) = vps(2)
                                       DataType(1) = 1000: Data(1) = "121209"
                                Case "121210"
                                       vps(0) = vps(0)
                                       vps(1) = vps(1)
                                       vps(2) = vps(2)
                                       Set tex = ThisDrawing.ModelSpace.AddText(dcrq, vps, Int(1.9 / 2 * 100) / 100)
                                       ent.Delete
                                       vps(0) = vps(0)
                                       vps(1) = vps(1) + 0.9 + 0.1 * 3
                                       vps(2) = vps(2)
                                       DataType(1) = 1000: Data(1) = "121210"
                                       vps(0) = vps(0)
                                       vps(1) = vps(1) - 2.15
                                       vps(2) = vps(2)
                                        Set tex = ThisDrawing.ModelSpace.AddText(chdw + chrq, vps, Int(1.9 / 2 * 100) / 100)
                                       tex.ScaleFactor = 1.375
                                       DataType(1) = 1000: Data(1) = "121288"
                                  Case "121203"
                                       ent.height = Int(2.7 / 2 * 100) / 100
                                       vps(0) = vps(0)
                                       vps(1) = vps(1)
                                       vps(2) = vps(2)
                                       ent.insertionPoint = vps
                                       Set tex = ThisDrawing.ModelSpace.AddText(ent.textString, vps, Int(3.6 / 2 * 100) / 100)
                                       DataType(1) = 1000: Data(1) = "121286"
                                       ent.Delete
                                  Case "121212"
                                      ' ent.TextString = "调查员: " + dcy
                                       vps(0) = vps(0)
                                       vps(1) = vps(1)
                                       vps(2) = vps(2)
                                     '  ThisDrawing.ActiveTextStyle.fontFile = "SIMFANG.TTF" '使用指定字体
                                       Set tex = ThisDrawing.ModelSpace.AddText("调查员: " + dcy, vps, Int(1.9 / 2 * 100) / 100)
                                       ent.Delete
                                       tex.ScaleFactor = 1.375 '调整宽高比例
                                       vps(0) = vps(0) + 10.4
                                       vps(1) = vps(1) + 1.3
                                       vps(2) = vps(2)
                                       DataType(1) = 1000: Data(1) = "121212"
                                  Case "121213"
                                       vps(1) = vps(1) + 1.3 + 0.5
                                       vps(2) = vps(2)
                                       Set tex = ThisDrawing.ModelSpace.AddText("测图员: " + cly, vps, Int(1.9 / 2 * 100) / 100)
                                       ent.Delete
                                       DataType(1) = 1000: Data(1) = "121213"
                                  Case "121214"
                                       vps(1) = vps(1) + 1.3 + 0.5 * 2
                                       vps(2) = vps(2)
                                       Set tex = ThisDrawing.ModelSpace.AddText("绘图员: " + hty, vps, Int(1.9 / 2 * 100) / 100)
                                       ent.Delete
                                       DataType(1) = 1000: Data(1) = "121214"
                                        vps(0) = vps(0)
                                       vps(1) = vps(1) - 2#
                                       vps(2) = vps(2)
                                        Set tex = ThisDrawing.ModelSpace.AddText("检查员: " + jcy, vps, Int(1.9 / 2 * 100) / 100)
                                       DataType(1) = 1000: Data(1) = "121289"
                                  Case "121201"
                                       ent.height = Int(6 / 2 * 100 * 6 / 7.5) / 100
                                       DataType(1) = 1000: Data(1) = "121201"
                                       ent.SetXData DataType, Data
                                  Case "121202"
                                       ent.height = Int(4.5 / 2 * 100) / 100
                                       ent.ScaleFactor = 0.8  '调整宽高比例
                                       DataType(1) = 1000: Data(1) = "121202"
                                       yjq10 = Right(Left(ent.textString, 7), 5)
                                       yjq11 = Right(ent.textString, 5)
                                       ent.textString = yjq10 + "-" + yjq11
                                  Case "121204"
                                      ' ThisDrawing.ActiveTextStyle.fontFile = "c:\WINDOWS\Fonts\FZZDXJW.TTF"
                                       ent.height = Int(3 / 2 * 100 * 3 / 3.5) / 100
                                       ent.ScaleFactor = 1.33 '调整宽高比例
                                       vps(0) = vps(0) - 2.5
                                       vps(1) = vps(1)
                                       vps(2) = vps(2)
                                       vps(0) = vps(0) - 31
                                       vps(1) = vps(1) + 0.15
                                       vps(2) = vps(2)
                                        Set tex = ThisDrawing.ModelSpace.AddText(dcqy + "地籍图", vps, Int(2.5 / 2 * 100 + 2.5 / 3) / 100)
                                       tex.ScaleFactor = 1.5
                                       DataType(1) = 1000: Data(1) = "121287"
                             End Select
GMT+8, 2026-11-22 10:45 , Processed in 0.405829 second(s), 12 queries , Gzip On, File On.
