查看: 1396|回复: 3
[求助] [求助]:帮忙看看一个LISP程序
发表于 2007-3-22 16:15:25 | 显示全部楼层 |阅读模式
(defun c:wl (/ l1 l2 pt1 pt2 pt3 pt4 ku)
       (setq olderr *error*
           *error* at_err)
       (if (setq l1 (getpoint "\nPick point:"))
       (while (setq l2 (getpoint l1 "\nPick point:"))
(setq old_osmode (getvar "osmode"))
(setq old_CMDECHO (getvar "CMDECHO"))
            (setvar "osmode" 0)
            (setvar "CMDECHO" 0)
       (setq ku (angle l1 l2))
       (setq pt1 (polar l1 (+ ku (* 0.5 pi)) 120))
       (setq pt2 (polar l1 (+ ku (* 1.5 pi)) 120))
       (setq pt3 (polar l2 (+ ku (* 0.5 pi)) 120))
       (setq pt4 (polar l2 (+ ku (* 1.5 pi)) 120))
       (command "Pline" pt1 "W" "60" "" pt3 pt4 pt2 "C" "")
       (setq *error* olderr)
(command "")
(setvar "osmode" old_osmode)
(setvar "CMDECHO" old_CMDECHO)
(setq l1 l2)
       (princ)
这是一个类似CAD中画双线的命令,执行后光标还是在L1点,而不是要求的L2点,请高手指正
发表于 2007-3-22 17:14:24 | 显示全部楼层
试一试下面这个:
  1. (defun c:wl (/ l1 l2 pt1 pt2 pt3 pt4 ku)
  2.     (setq olderr  *error*
  3.           *error* at_err
  4.     )
  5.     (setq old_CMDECHO (getvar "CMDECHO"))
  6.     (setvar "CMDECHO" 0)
  7.     (if        (setq l1 (getpoint "\n第一点:"))
  8.         (while (setq l2 (getpoint l1 "\n下一点:"))
  9.             (setq ku  (angle l1 l2)
  10.                   pt1 (polar l1 (+ ku (* 0.5 pi)) 120)
  11.                   pt2 (polar l1 (+ ku (* 1.5 pi)) 120)
  12.                   pt3 (polar l2 (+ ku (* 0.5 pi)) 120)
  13.                   pt4 (polar l2 (+ ku (* 1.5 pi)) 120)
  14.             )
  15.             (setq old_osmode (getvar "osmode"))
  16.             (setvar "osmode" 0)
  17.             (command "Pline" pt1 "W" "60" "" pt3 pt4 pt2 "C")
  18.             (setvar "osmode" old_osmode)
  19.             (setq l1 l2)
  20.         )
  21.     )
  22.     (setq *error* olderr)
  23.     (setvar "CMDECHO" old_CMDECHO)
  24.     (princ)
  25. )
 楼主| 发表于 2007-3-22 17:26:06 | 显示全部楼层
朋友,再次谢谢你,问题解决.
我在此提出的几个问题都是你帮忙解决的,再次谢谢你
对你这样的热心肠,班主应该加分
发表于 2007-3-24 09:05:07 | 显示全部楼层
相互学习,共同提高!
GMT+8, 2026-11-22 10:01 , Processed in 0.357141 second(s), 16 queries , Gzip On, File On.
