查看: 2053|回复: 2
[求助]:关于CAdUiPalette的问题求助
发表于 2007-4-28 21:28:01 | 显示全部楼层 |阅读模式
各位大虾,我用CAdUiPalette和CAdUiPaletteSet作了一个自定义图形的工具,在CAdUiPalette中加入了一个ChildDlg模板,有一个Button类按钮,用此按钮绘制图形,可在绘制时出现无法以AcDb::kForWrite方式打开块表记录(AcDbBlockTableRecord)的问题,以AcDb::kForRead方式可以打开(当然也无法绘图),不知是何原因,请指教!!!!!!!!!!
void GZGPaletteChildDlg::OnBnClickedButtonInsert()
        // TODO: 在此添加控件通知处理程序代码        double rh,rb,rd,rt,rr,rr1;
        CString numstr;
        rh=_wtof(m_datalist.get_TextMatrix(1,1));
        rb=_wtof(m_datalist.get_TextMatrix(2,1));
        rd=_wtof(m_datalist.get_TextMatrix(3,1));
        rt=_wtof(m_datalist.get_TextMatrix(4,1));
        rr=_wtof(m_datalist.get_TextMatrix(5,1));
        rr1=_wtof(m_datalist.get_TextMatrix(6,1));
        double scale;
        AcGePoint3d basePt;
        int retcade=acedGetReal(_T("\n比例<1>:"),&scale);
        if(retcade!=RTERROR && retcade!=RTCAN)
                if(retcade==RTNONE)
                        scale=1;
                acedInitGet(RSG_NONULL,_T("J T F"));
                TCHAR retstr;
                if(acedGetKword(_T("\n选择视图\n<截面(J)/俯视(T)/侧视(F)>:"),&retstr)==RTNORM)
                        if(_tcscmp(&retstr,_T("J"))==0)
                                acedInitGet(RSG_NONULL,_T("C B T"));
                                TCHAR str;
                                if(acedGetKword(_T("\n插入基点\n<中心(C)/底部中心(B)/顶部中心(T)>:"),&str)==RTNORM)
                                        if(_tcscmp(&str,_T("C"))==0)
                                                basePt.set(0,0,0);
                                        DrawGZGSection(scale,basePt, rh,rb,rd,rt,rr,rr1);
void GZGPaletteChildDlg::DrawGZGSection(double scale, AcGePoint3d inpt, double h, double b, double d, double t, double r, double r1)
ads_name Last_Line,GZGss;
acedSSAdd(NULL,NULL,GZGss);
        //Acad::ErrorStatus es;
        AcDbDatabase * CurDataBase = NULL;
        CurDataBase = acdbHostApplicationServices()->workingDatabase();
        if(CurDataBase == NULL)
                acutPrintf(_T("\n图形错误!"));
                return;
        AcDbBlockTable* CurBlockTable;
        if((CurDataBase->getSymbolTable(CurBlockTable,AcDb::kForRead))!=Acad::eOk)
                acutPrintf(_T("\n块表打开错误!"));
                return;
        AcDbBlockTableRecord* CurBlockTableRec;
        if(CurBlockTable->getAt(ACDB_MODEL_SPACE,CurBlockTableRec,AcDb::kForWrite,false)!=Acad::eOk)//出现问题
                CurBlockTable->close();
                acutPrintf(_T("\n块表记录打开错误!"));
                return;
        CurBlockTableRec->close();
发表于 2007-4-29 08:36:03 | 显示全部楼层
在函数最前面加一句, acaxdoclock lock;
 楼主| 发表于 2007-4-29 22:31:55 | 显示全部楼层
谢谢binbin  的指点
GMT+8, 2026-11-4 05:19 , Processed in 0.433894 second(s), 36 queries , Gzip On.
