查看: 1228|回复: 0
[LISP程序]:动态生成SOLID,哪位高人帮完善一下.
发表于 2007-7-28 08:10:32 | 显示全部楼层 |阅读模式
(DEFUN c:aa ( / boolean code ent motion pt1 pt2 pt4 ptbase)
  (COMMAND ".UCS" "W")
  (setvar "osmode" 767)
(defun get_point( / ptbase)
(setq ptbase (GETCORNER PT1 "\n另一角点 :"))
(SETQ PT1 (GETPOINT "\n建柱子左下角点 :"))
(setq boolean t)
(while boolean
(setq motion (grread t 15 0))
(setq code (car motion))
(setq ptbase (cadr motion))
(cond
((= code 5)
(SETQ
        PT2 (LIST (CAR PT1) (CADR ptbase))
        PT4 (LIST (CAR ptbase) (CADR PT1))
(setq ent (list (cons 0 "SOLID")
(cons 10 pt1) (cons 11 pt2) (cons 12 pt4) (cons 13 ptbase) (cons 62 256)
(entmake ent)
(entupd (entlast))
((= code 3)
(setq boolean nil)
((= code 11)
(entdel (cdr (assoc -1 ent)))
(setq boolean nil)
  (COMMAND ".UCS" "P")
  (PRINC)
;动态生成SOLID,如何让这个程在点取后才生成物体?并且为何捕捉会没了?
GMT+8, 2026-11-22 08:31 , Processed in 0.225524 second(s), 10 queries , Gzip On, File On.
