查看: 1451|回复: 3
[求助] [编程申请]:(求助)关于模型选项卡与布局选项卡的切换的编程
发表于 2007-9-27 00:15:51 | 显示全部楼层 |阅读模式
说得简单点就是Tilemode和layout(command "layout" "s")两个命令融合为一体的lisp的程序
发表于 2007-9-27 08:37:36 | 显示全部楼层
给个参照的程序....
[php]
;;全屏显示/关闭的切换。 _By  dwg001   2006-12-07
(defun c:tt ()
  (setvar "cmdecho" 0)
  (if (null temp)
    (setq temp 0)
  (if (= 0 temp)
    (progn
      (setq temp 1)
      (command "_.cleanscreenOFF")
    (progn
      (setq temp 0)
      (command "_.cleanscreenON")
  (princ)
[/php]
发表于 2007-9-27 14:24:12 | 显示全部楼层
[php]
;开关
(defun c:ti ()
(setvar "Tilemode" (-(getvar "Tilemode") 1))
[/php]
 楼主| 发表于 2007-9-30 01:06:54 | 显示全部楼层
carrot1983兄,谢谢提供参照程序问题解决了,谢谢!!!!
GMT+8, 2026-11-22 09:14 , Processed in 0.319707 second(s), 16 queries , Gzip On, File On.
