查看: 1681|回复: 1
[LISP函数]:用ALISP重写VL-REMOVE等
发表于 2007-10-10 15:53:08 | 显示全部楼层 |阅读模式
  1.   [FONT=courier new]
  2. ;;; ==================================================================
  3. (defun txt-remove (x lst)
  4.   (setq lst (txt-list-subtract lst (list x)))
  5. )
  6. ;;; ==================================================================
  7. (defun th-remove-if (pred lst)
  8.   (foreach x lst
  9.     (if (apply
  10.           pred
  11.           (list x)
  12.         )
  13.       (setq lst (txt-list-subtract lst (list x)))
  14.     )
  15.   )
  16.   lst
  17. )
  18. ;;; ==================================================================
  19. (defun th-remove-if-not (pred lst)
  20.   (foreach x lst
  21.     (if (not (apply
  22.                pred
  23.                (list x)
  24.              )
  25.         )
  26.       (setq lst (txt-list-subtract lst (list x)))
  27.     )
  28.   )
  29.   lst
  30. )
  31. ;;; ==================================================================
  32. ;;; 命令: (th-remove-if-not '(lambda(x)(> x 8)) lst)
  33. ;;; (17 9)
  34. ;;; 命令: (th-remove-if '(lambda(x)(> x 8)) lst)
  35. ;;; (1 2 3 3 2 1 6 5 1 5 6 8 1 8 1 6 5 1 4 5 1)
  36. ;;; 命令: (txt-remove 1 lst)
  37. ;;; (2 3 3 2 6 5 5 6 17 8 9 8 6 5 4 5)
  38. ;;; 命令: !lst
  39. ;;; (1 2 3 3 2 1 6 5 1 5 6 17 8 1 9 8 1 6 5 1 4 5 1)
  40. ;;; ==================================================================
  41. (defun txt-list-subtract (lst1 lst2 / lst)
  42.   (setq lst '())
  43.   (if lst1
  44.     (foreach tmp lst1
  45.       (if (not (member tmp lst2))
  46.         (setq lst (cons tmp lst))
  47.       )
  48.     )
  49.   )
  50.   (setq lst (reverse lst))
  51.   lst
  52. )
  53. ;;; ==================================================================
  54.   [/FONT]
另外一种写法:
  3. ;;; 命令: (th-remove-if '(lambda(x)(< x 5))lst)
  4. ;;; (3 1 2 3 4 0 0 4 3 2 1 1 1)
  5. ;;; 命令: (th-remove-if-not '(lambda(x)(< x 5))lst)
  6. ;;; (12 5 6 7 8 9 9 8 7 6 5 5 6 6)
  7. ;;; 命令: (th-remove 1 lst)
  8. ;;; (12 3 2 3 4 5 6 7 8 9 0 0 9 8 7 6 5 4 3 2 5 6 6)
  9. ;;; 命令: !lst
  10. ;;; (12 3 1 2 3 4 5 6 7 8 9 0 0 9 8 7 6 5 4 3 2 1 1 1 5 6 6)
  11. (defun th-remove (ele lst)
  12.   (apply
  13.     'append
  14.     (mapcar
  15.       (function (lambda (x)
  16.                   (if (/= x ele)
  17.                     (list x)
  18.                   )
  19.                 )
  20.       )
  21.       lst
  22.     )
  23.   )
  24. )
  25. (defun th-remove-if-not (pred lst)
  26.   (apply
  27.     'append
  28.     (mapcar
  29.       (function (lambda (x)
  30.                   (if (apply
  31.                         pred
  32.                         (list x)
  33.                       )
  34.                     (list x)
  35.                   )
  36.                 )
  37.       )
  38.       lst
  39.     )
  40.   )
  41. )
  42. (defun th-remove-if(pred lst)
  43.   (apply
  44.     'append
  45.     (mapcar
  46.       (function (lambda (x)
  47.                   (if (not (apply
  48.                              pred
  49.                              (list x)
  50.                            )
  51.                       )
  52.                     (list x)
  53.                   )
  54.                 )
  55.       )
  56.       lst
  57.     )
  58.   )
  59. )
  60. ;;; ==================================================================
  61.   [/FONT]
发表于 2013-6-12 14:00:03 | 显示全部楼层
tanger 写得太好,学习
GMT+8, 2026-11-22 10:32 , Processed in 0.251232 second(s), 12 queries , Gzip On, File On.
