查看: 1314|回复: 5
[求助] [求助]:求一能统计图中所有直线总长度的lisp?
发表于 2007-12-18 17:39:42 | 显示全部楼层 |阅读模式
有没有办法实现这样的功能,就是统计图中所有直线总长度的lisp?
已领礼包: 9348个
发表于 2007-12-18 18:20:55 | 显示全部楼层
发表于 2007-12-19 08:09:46 | 显示全部楼层
(defun c:test(/ curve tlen ss n sumlen)
  (vl-load-com)
  (setq sumlen 0)
  (setq ss (ssget '((0 . "CIRCLE,ELLIPSE,LINE,*POLYLINE,SPLINE,ARC"))))
  (setq n 0)
  (repeat (sslength ss)
    (setq curve (vlax-ename->vla-object (ssname ss n)))
    (setq tlen (vlax-curve-getdistatparam curve
                                          (vlax-curve-getendparam curve)
    (setq sumlen (+ sumlen tlen))
    (setq n (1+ n))
  (alert (strcat "\n总长度: " (rtos sumlen 2 3) (princ "m")))
  (princ)
发表于 2007-12-19 08:25:58 | 显示全部楼层
就在这个版块里以前发过类似的lisp
你可以找一下
 楼主| 发表于 2007-12-20 11:02:03 | 显示全部楼层
多谢三楼,测试可行。非常感谢
发表于 2007-12-20 12:28:50 | 显示全部楼层
不错
GMT+8, 2026-11-7 10:46 , Processed in 0.407743 second(s), 41 queries , Gzip On.
