查看: 1459|回复: 5
[求助] [求助]:帮我看看这个LISP为什么不能在R14下用
发表于 2008-8-22 20:08:25 | 显示全部楼层 |阅读模式
帮我看看这个LISP为什么不能在R14下用,2004上能用,但我一直都是用R14.
下面是代码
tz.DCL
tz : dialog{
label="文字替换";
:row {
:column {
:edit_box{
label="文字替换内容:";
width=40;
key="wbnr";}
:row {
:button{
label="添加到本机";
key="wbtj";
fixed_width = true;
width=11;}
:button{
label="从本机删除";
key="wbsc";
fixed_width = true;
width=11;
:list_box{
label="本机已有文字内容:";
list="本机已有文字内容\n";
value="0";
key="wbbc";
width=30;
height=10;}
:row{
:button{
label="选择需替换的文本";
key="wbxz";
fixed_width = true;
width=11;}
:cancel_button{
fixed_width=true;
width=11;
tz.lsp
;;;调用菜单
(defun c:tz ()
(setq flag 4)
(setq dcl_id (load_dialog "tz.dcl"))
(if (< dcl_id 0) (exit))
(if (not (new_dialog "tz" dcl_id))
(exit)
(setq txtfile (findfile "tz.txt"))
(setq txtlist (Get_Txt txtfile))
(additems "wbbc" txtlist)
  (while (> flag 2)
  (action_tile "wbtj" "(wbtj)")
  (action_tile "wbbc" "(wbbc $value)")
  (action_tile "wbsc" "(wbsc)")
  (action_tile "wbxz" "(wbxz0)(done_dialog 1)")
  (action_tile "cancel" "(done_dialog 0)")
    (setq flag (start_dialog))
    (if (= flag 1)
       (wbxz wbnrn txtlist))
  (unload_dialog dcl_id)
(princ)
;;;把本机上文本添入菜单中
(defun wbtj()
(setq txtlist (append txtlist (list (get_tile"wbnr"))))
;;;把本机上文本删除
(defun wbsc()
(setq txtlist (vl-remove wbnrn txtlist))
(defun wbbc(vva)
(setq wbnrn (nth (atoi vva) txtlist))
(set_tile "wbnr" wbnrn)
(defun wbxz0()
(setq wbnrn (get_tile "wbnr"))
(defun wbxz(wbnrn txtlist / ent1 ent2)
(if txtlist
(write_Txt txtfile txtlist)
(vl-load-com)
(setq ent1 (vlax-ename->vla-object (car (entsel))))
(setq ent2 (vla-put-textstring ent1 wbnrn))
;;将文本文件中的内容转换为列表
(defun Get_Txt (datfile / tmplst x fn)
  (setq fn (open datfile "r"))
  (while (setq x (read-line fn))
        (setq tmplst(append tmplst(list x)))
     (close fn)
  tmplst
已领礼包: 12483个
发表于 2008-8-23 23:07:53 | 显示全部楼层
将所有VL开头的函数替换掉就可以在R14中运行了。
已领礼包: 1915个
财富等级: 堆金积玉
发表于 2008-8-23 23:13:41 | 显示全部楼层
R14 不支持带有VL开头的函数
发表于 2008-8-24 17:14:17 | 显示全部楼层
把这段
(vl-load-com)
更改为
(setq xzwb (car (entsel))
     xzwblb (entget xzwb)
      thwbnr (assoc 1 xzwblb)
      xzwbnr (cons 1 wbnrn)
      xzwblb (subst xzwbnr thwbnr xzwblb))
(entmod xzwblb)
(entupd xzwb)
应该就可以了,我没有R14,无法调试.
 楼主| 发表于 2008-8-24 21:42:58 | 显示全部楼层
最初由 791221ni 发布
[B]把这段
(vl-load-com)
更改为
      thwbnr (ass... [/B]
谢谢,已经修改成功!
发表于 2008-8-26 16:14:09 | 显示全部楼层
不错
GMT+8, 2026-11-3 10:49 , Processed in 0.517833 second(s), 42 queries , Gzip On.
