查看: 2556|回复: 3
[LISP函数]:定界符分割文字成表
发表于 2009-2-8 08:32:25 | 显示全部楼层 |阅读模式
定界符分割文字成表
  1.   [FONT=courier new]
  2. (defun txt-str-split (str x / lst n str-n xlen)
  3.   (setq xlen (strlen x))
  4.   (while (setq n (vl-string-search x str))
  5.     (setq str-n (substr str 1 n))
  6.     (if        (/= str-n "")
  7.       (setq lst (cons str-n lst))
  8.     )
  9.     (setq str (substr str (+ 1 xlen n)))
  10.   )
  11.   (if (/= str "")
  12.     (setq lst (cons str lst))
  13.   )
  14.   (reverse lst)
  15. )
  16. (defun ybl-str-parse (str delimiter / post strlst sl);eachy
  17.   (if str
  18.     (progn
  19.       (setq strlst '()
  20.             sl           (+ (strlen delimiter) 1)
  21.       )
  22.       (while (vl-string-search delimiter str)
  23.         (setq post (vl-string-search delimiter str))
  24.         (setq strlst (append
  25.                        strlst
  26.                        (list (substr str 1 post))
  27.                      )
  28.         )
  29.         (setq str (substr str (+ post sl)))
  30.       )
  31.       (vl-remove ""
  32.                  (append
  33.                    strlst
  34.                    (list str)
  35.                  )
  36.       )
  37.     )
  38.   )
  39. )
  40. (defun tt-str-split (str sep / lst pos)
  41.   (setq        lst (if        (setq pos (vl-string-search sep str))
  42.               (cons (substr str 1 pos)
  43.                     (tt-str-split
  44.                       (substr str
  45.                               (+
  46.                                 (strlen sep)
  47.                                 pos
  48.                                 1
  49.                               )
  50.                       )
  51.                       sep
  52.                     )
  53.               )
  54.               (list str)
  55.             )
  56.   )
  57.   (vl-remove "" lst)
  58. )
  59.   [/FONT]
发表于 2013-5-1 14:01:30 | 显示全部楼层
这么好的函数,一定支持
发表于 2013-5-1 14:13:55 | 显示全部楼层
先收下了,谢谢
发表于 2013-6-12 12:35:46 | 显示全部楼层
谢谢tanger了,用处很大
GMT+8, 2026-11-22 08:29 , Processed in 0.372544 second(s), 16 queries , Gzip On, File On.
