查看: 7919|回复: 12
[标注] 图块标注定位尺寸
发表于 2016-11-3 09:10:01 | 显示全部楼层 |阅读模式
  • 插件名称 : 标注图块
  • 作  者 : Lispboy
  • 运行环境 :XDRX API 晓东工具箱
  • 发布时间 :2016-11-03
  • 命令名称 :XDTB_DIMBRK
  • 插件介绍 :标注图块尺寸
  • 备  注 : (点击图片可以放大)
(点击图片可以放大)
2、在ACAD中如何加载插件,请看 论坛插件使用方法
3、如果您有要求需要定制插件,请到 编程申请 论坛发帖求助
插件详细内容
[sell]
(defun c:XDTB_DimBlk (/ base base1 base2 box direc down dynpt keyword lst
                        mat mat1 mat2 offset p1 p2 pt pts scl ss ss1 up x
                        xdir ydir
  (defun _prompt ()
    (xdrx_prompt "\n当前设置:基点偏移[" #blk_dim_baseoffset "]/尺寸长度["
                 #blk_dim_jxlength "]"
  (defun _keyword (keyword)
    (cond
      ((= keyword "TC")
        (if (setq offset (getreal (xdrx_prompt "\n输入基点偏移距离<"
                                               #blk_dim_baseoffset ">:" t
          (setq #blk_dim_baseoffset offset)
      ((= keyword "JX")
        (if (setq offset (getreal (xdrx_prompt "\n输入尺寸线长度<"
                                               #blk_dim_jxlength ">:" t
          (setq #blk_dim_jxlength offset)
    (_prompt)
  (defun _data ()
    (setq xdir (getvar "ucsxdir")
          box (xdrx_entity_box ss)
          p1 (car box)
          p2 (mapcar
               p1
               xdir
          base1 (list p1 p2)
          base2 (list (last box) (mapcar
                                   (last box)
                                   xdir
          base (list (xd::geom:get9pt ss 4) (xd::geom:get9pt ss 6))
          pts (mapcar
                '(lambda (x)
                   (xdrx_getpropertyvalue x "position")
                (xdrx_pickset->ents ss)
          ydir (xdrx_vector_perpvector xdir)
          mat (xdrx_matrix_identity 3)
          mat1 (xdrx_matrix_settranslation mat (xdrx_vector_product ydir
        (- #blk_dim_baseoffset)
          mat2 (xdrx_matrix_settranslation mat (xdrx_vector_product ydir
        (- #blk_dim_jxlength)
          pts (xdrx_points_sortOnCurve (list p1 p2) pts t)
          pts (mapcar
                'car
                pts
          pts (xdrx_points_transform pts mat1)
          pt (xdrx_point_transform (car pts) mat2)
    (xdrx_setmark)
    (xd::dim:init)
    (xd::dim:makerotwithPnts pts pt t nil)
    (setq ss1 (xdrx_getss))
    (xdrx_dimension_setoverride ss1 40 scl)
    (_drag ss1)
  (defun _drag (ss)
    (defun _callback (dynpt)
      (setq pt (xd::geom:get9pt ss 5))
      (setq up (XD::Pnt:IsLeftTopByLine dynpt (car base2) (cadr base2))
            direc (XD::Pnt:IsLeftTopByLine pt (car base2) (cadr base2))
      (if up
        (progn
          (if (not direc)
            (progn
              (xdrx_entity_mirror ss base t)
      (setq down (not (XD::Pnt:IsLeftTopByLine dynpt (car base1)
                                               (cadr base1)
            direc (not (XD::Pnt:IsLeftTopByLine pt (car base1)
                                                (cadr base1)
      (if down
        (progn
          (if (not direc)
            (progn
    (xdrx_pointmonitor "_callback")
    (getpoint "\n移动鼠标确定方向<结束>:")
    (xdrx_pointmonitor)
  (xdrx_begin)
  (if (not #blk_dim_jxlength)
    (setq #blk_dim_jxlength 30.)
  (if (not #blk_dim_baseoffset)
    (setq #blk_dim_baseoffset 10.)
  (setq scl (xd::var:getscaleratio))
  (if (and
        (_prompt)
        (xdrx_initssget "\n选取要标注的图块[偏移距离(TC)/尺寸长度(JX)]<退出>:"
                        "TC JX" "移除不标注的图块[添加(A)]<退出>:"
                        "_keyword" ""
        (setq ss (xdrx_ssget '((0 . "INSERT"))))
    (progn
      (setq lst (_data))
  (xdrx_end)
  (princ)
[/sell]
发表于 2016-11-3 11:00:23 | 显示全部楼层
正需要,支持楼主大人了!
发表于 2016-11-3 11:09:32 | 显示全部楼层
啥也不说了,感谢楼主分享哇!
发表于 2018-1-23 08:07:35 | 显示全部楼层
谢谢楼主分享!
发表于 2020-7-19 08:35:15 | 显示全部楼层
使用了你的图块尺寸工具,加载后,提示错误信息。同时我想询问下,你的这个工具能不能测量图块的长宽尺寸大小?
发表于 2020-7-20 12:58:21 | 显示全部楼层
太好了,非常需要!好思路啊
发表于 2020-7-22 11:24:48 | 显示全部楼层
感谢楼主分享,这个插件很实用!
发表于 2020-8-14 10:55:17 | 显示全部楼层
看着不错的
发表于 2020-10-27 09:55:29 | 显示全部楼层
看看正好需要这种的标注工具
发表于 2020-12-28 16:02:57 | 显示全部楼层
谢谢楼主分享,好插件一起使用!
发表于 2020-12-28 16:26:31 | 显示全部楼层
插件会出现错误信息,请问如何处理?
发表于 2021-5-15 11:47:34 | 显示全部楼层
找了好久,感谢楼主大人
发表于 2024-8-1 19:09:31 | 显示全部楼层
感谢分享,太实用了
GMT+8, 2026-11-22 09:33 , Processed in 0.188501 second(s), 34 queries , Gzip On, File On.
