查看: 799|回复: 2
[试用]:Restoring a Lost Command Line
发表于 2003-8-13 06:28:57 | 显示全部楼层 |阅读模式
Sometimes users get in a hurry or just aren't careful, and can accidentally drag and drop the command line area, losing it in the process.  Carefully follow this Registry Edit procedure to get it back.
Shut down AutoCAD if it's running.
Click on Start, then choose Run.
Type REGEDIT and choose OK.
On the left pane, double click on "HKEY_CURRENT_USER".
Double click on "Software".
Double click on "Autodesk".
Double click on "AutoCAD".
Double click on "R15.0"
Double click on "ACAD-###:###".
Double click on "Fixed Profile".
Double click on "Command Line Windows".
On the right pane, double click on "Dock Window Position".
Several numbers should be highlighted, simply press "0".
Choose OK, then close the Registry Editor.
Restart AutoCAD, the command prompt should be back.
发表于 2003-8-13 09:15:40 | 显示全部楼层
这样
发表于 2003-8-13 09:34:35 | 显示全部楼层
大哥,英文啊,看得不是很明白啊!!!
不过很有用,也可以解决命令行消失的问题,谢谢!!!
REGEDIT4
[HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R15.0\ACAD-1:804\FixedProfile\Command Line Windows]
"TextWindow.Show"=dword:00000001
"TextWindow.Position"="72 96 728 478"
"CmdLine.Rows"=dword:0000000f
"DockWindow.Style"=dword:00000000
"DockWindow.Position"="158 608 558 816"
*-*9 *-*9 *-*9
GMT+8, 2026-11-3 04:01 , Processed in 0.528806 second(s), 37 queries , Gzip On.
