查看: 866|回复: 3
[LISP程序]:文字串搜索替换
发表于 2003-8-14 15:54:51 | 显示全部楼层 |阅读模式
  1.   [FONT=courier new]
  2. (defun myerr (s)
  3.         (if (/= s "Function cancelled")
  4.                 (princ (strcat "\nError: " s))
  5.         )
  6.         (setq tset nil)
  7.         (setq *error* olderr)
  8.         (princ)
  9. )
  10. (defun C:texsrch (/ tset l n e os as ns st s nsl osl sl si chf chm olderr)
  11.         (setq
  12.                 olderr *error*
  13.                 *error* myerr
  14.                 chm 0
  15.         )
  16.         (menucmd "S=SELECT")
  17.         (prompt "\n选取要编辑的文字 <所有>: ")
  18.         (if (null (setq tset (ssget '((0 . "TEXT")))))
  19.                 (setq tset (ssget "x" (list (cons 0 "TEXT"))))
  20.         )
  21.         (menucmd "S=")
  22.         (cond
  23.                 ((null tset) (prompt "\n图形中不存在TEXT文字."))
  24.                 (t (terpri)
  25.                         (princ (itoa (sslength tset)))
  26.                         (prompt " 个TEXT文字选取.")
  27.                         (command "undo" "mark")
  28.                 )
  29.         )
  30.         (cond
  31.                 ((null tset) (prompt "\nNothing Modified."))
  32.                 (t
  33.                         (while (= 0 (setq osl (strlen
  34.                                 (setq os (getstring t "\n要替换的字符: ")))))
  35.                                 (princ "无效的空输入")
  36.                         )
  37.                         (setq nsl (strlen (setq ns (getstring t "\n新字符: "))))
  38.                         (setq l 0 n (sslength tset))
  39.                         (while (< l n)
  40.                                 (if (= "TEXT" (cdr (assoc 0 (setq e (entget (ssname tset l))))))
  41.                                         (progn
  42.                                                 (setq
  43.                                                         chf nil
  44.                                                         si 1
  45.                                                         s (cdr (setq as (assoc 1 e)))
  46.                                                 )
  47.                                                 (while (= osl (setq sl (strlen
  48.                                                         (setq st (substr s si osl)))))
  49.        (if (= st os)
  50.        (progn
  51.        (setq s (strcat (substr s 1 (1- si)) ns
  52.        (substr s (+ si osl)
  53.        )))
  54.        (setq chf t)
  55.        (setq si (+ si nsl))
  56.        )
  57.        (setq si (1+ si))
  58.                                                         )
  59.                                                 )
  60.                                                 (if chf
  61.                                                         (progn
  62.        (setq e (subst (cons 1 s) as e))
  63.        (entmod e)
  64.        (setq chm (1+ chm))
  65.                                                         )
  66.                                                 )
  67.                                         )
  68.                                 )
  69.                                 (setq l (1+ l))
  70.                         )
  71.                         (princ "改变了 ")
  72.                         (princ chm)
  73.                         (prompt " 个 text 行.")
  74.                 )
  75.         )
  76.         (setq *error* olderr)
  77.         (princ)
  78. )
  79.   [/FONT]
已领礼包: 488个
发表于 2003-8-14 22:12:43 | 显示全部楼层
应该没cad自带的"_find"好
 楼主| 发表于 2003-8-15 16:28:13 | 显示全部楼层
R14中好像没有FIND(如没装bouns)
发表于 2003-8-16 09:21:31 | 显示全部楼层
hqd9639兄:你的lisp程序我试了一下,替换功能是有了,可查找的功能没有。如果能够加上自动查找功能就好了。也就是说,能够自动查找相同的字符串,修改其中的字符。对于lisp编程,我是外行,只会用,不会写,仅提建议。
GMT+8, 2026-11-3 20:09 , Processed in 0.684104 second(s), 38 queries , Gzip On.
