查看: 852|回复: 1
[LISP程序]:一个改园半径的LISP供大家
发表于 2003-8-20 14:29:23 | 显示全部楼层 |阅读模式
  1. (defun c:ch-rad()
  2. (setq scal (getreal "rad :"))
  3.        (setq ss (ssget "x" '((0 . "CIRCLE"))))
  4. (setq n (sslength ss))
  5. (setq index 0)
  6. (repeat n
  7. (setq tname (ssname ss index))
  8.    (setq index (+ 1 index))
  9.                 (setq tget (entget tname))
  10.                 (setq txtdata (cdr (assoc 40 tget)))
  11.                 (setq txtlist (cons 40 scal) )
  12.                 (setq tget (subst  txtlist (assoc 40 tget) tget))
  13.                 (entmod tget)
  14. )
  15. )
发表于 2003-8-20 15:29:47 | 显示全部楼层
Vlisp程序可能更简明些:
  1. (defun c:test ()
  2.   (vl-load-com)
  3.   (prompt "Select circles:")
  4.   (setq ss (ssget) n 0)
  5.   (setq rad (getreal "Type in Radius:"))
  6.   (while (< n (sslength ss))
  7.     (setq obj (vlax-ename->vla-object (ssname ss n)))
  8.     (vla-put-radius obj rad)
  9.     (setq n (1+ n))
  10.   )
  11. );defun
GMT+8, 2026-11-3 13:58 , Processed in 0.688373 second(s), 34 queries , Gzip On.
