查看: 898|回复: 0
[VBA函数]:给数组内数从大到小排序
发表于 2002-11-15 18:09:32 | 显示全部楼层 |阅读模式
给数组内数从大到小排序
  1. Sub BubbleSort(List() As Double)
  2. '   Sorts an array using bubble sort algorithm
  3.     Dim First As Double, Last As Double
  4.     Dim i As Integer, j As Integer
  5.     Dim Temp As Double
  6.
  7.     First = LBound(List)
  8.     Last = UBound(List)
  9.     For i = First To Last - 1
  10.         For j = i + 1 To Last
  11.             If List(i) > List(j) Then
  12.                 Temp = List(j)
  13.                 List(j) = List(i)
  14.                 List(i) = Temp
  15.             End If
  16.         Next j
  17.     Next i
  18. End Sub
GMT+8, 2026-11-2 04:02 , Processed in 0.443393 second(s), 32 queries , Gzip On.
