查看: 1043|回复: 1
[ARX程序]:办忙了
发表于 2002-11-24 22:40:41 | 显示全部楼层 |阅读模式
编译通过(为什么运行重视出现对话框‘读写错误“
谢指点)dys-cj@home.ncidi.com...
原程序如下:
CString fname=getfilename.file1;
        CString addintional="d:\\";
        fname=addintional+fname+".dwg";
        //additional prase
        acutPrintf("fname.....%s\n",fname);
        //end.cj
        AcDbDatabase* pDb;
        AcDbObjectId transId;
        pDb = new AcDbDatabase(Adesk::kFalse);
        pDb->readDwgFile(fname);
    if (pDb->readDwgFile(fname) != Acad::eOk)
        acutPrintf("\nSorry, that draing is probably already open.\n");
        return;
    // Get the Block Table and then the model space record.
    AcDbBlockTable *pBlockTable;
    pDb->getSymbolTable(pBlockTable, AcDb::kForRead);
    AcDbBlockTableRecord *pOtherMsBtr;
    pBlockTable->getAt(ACDB_MODEL_SPACE, pOtherMsBtr, AcDb::kForRead);
    pBlockTable->close();
    // Create an iterator.
    AcDbBlockTableRecordIterator *pIter;
    pOtherMsBtr->newIterator(pIter);
    // Set up an object ID array.
    AcDbObjectIdArray objIdArray;
    // Iterate over the model space BTR. Look specifically
    // for lines and append their object ID to the array.
    for (pIter->start(); !pIter->done(); pIter->step())
        AcDbEntity *pEntity;//AcDbText *pEntitytext;
        pIter->getEntity(pEntity, AcDb::kForRead);
        // Look for only AcDbLine objects and add them to the
        // object ID array.
        if (pEntity->isKindOf(AcDbText::desc()))
            objIdArray.append(pEntity->objectId());
        //        pEntitytext->close();
                acutPrintf("111d\n");
        pEntity->close();
    delete pIter;
    pOtherMsBtr->close();
    if (objIdArray.isEmpty())
        //acutPrintf("\nYou must pick a drawing file that contains lines.");
        return;
    // Now get the current database and the object ID for the
    // current database's model space BTR.
    AcDbBlockTable *pThisBlockTable;
    acdbHostApplicationServices()->workingDatabase()
        ->getSymbolTable(pThisBlockTable, AcDb::kForRead);
    AcDbBlockTableRecord *pThisMsBtr;
    pThisBlockTable->getAt(ACDB_MODEL_SPACE, pThisMsBtr, AcDb::kForWrite);
    pThisBlockTable->close();
    AcDbObjectId id = pThisMsBtr->objectId();
    pThisMsBtr->close();
    // Create the long transaction. This will check all the entities
    // out of the external database.
    AcDbIdMapping errorMap;
    acapLongTransactionManagerPtr()->checkOut(transId, objIdArray, id, errorMap);
    // Now modify the color of these entities.
    AcDbObject* pObj;
        //w .by.cj
        //w.by.cj
    if (acdbOpenObject(pObj, transId, AcDb::kForRead) == Acad::eOk)
        AcDbLongTransaction* pLongTrans = AcDbLongTransaction::cast(pObj);
        if (pLongTrans != NULL)
            // Get a work set iterator.
            AcDbLongTransWorkSetIterator* pWorkSetIter;
            pLongTrans->newWorkSetIterator(pWorkSetIter);
                        //add///cj
                        for (pWorkSetIter->start(); !pWorkSetIter->done(); pWorkSetIter->step())
                AcDbText *pEntity;
                acdbOpenObject(pEntity, pWorkSetIter->objectId(), AcDb::kForWrite);
                //假如语句
        if(pEntity->textString()=="yyy"
pEntity->setTextString("xxx");
                    pEntity->close();
            delete pWorkSetIter;
        pObj->close();
     acapLongTransactionManagerPtr()->checkIn(transId, errorMap);
        pDb->saveAs(fname);
        delete pDb;
        pDb = NULL;
        acutPrintf("ddd,end....%s",fname);
//        acad_free(fname);
发表于 2002-11-25 08:48:33 | 显示全部楼层
请不要重复发主题,浪费别人时间!
GMT+8, 2026-11-3 04:01 , Processed in 0.500287 second(s), 34 queries , Gzip On.
