查看: 1264|回复: 0
[原创]:新写的一个目录选取函数
发表于 2005-4-7 12:19:27 | 显示全部楼层 |阅读模式
写程序时常用到这个函数,而又不想用外挂API,就把它写了下来。
  1.   [FONT=courier new]
  2. (defun HBrowseFolder (msg / index dirlist obj folders path1 dirlist0 path)
  3.   (if (null msg)
  4.     (setq msg "Select folder")
  5.   )
  6.   (setq index T)
  7.   (setq dirlist '() path nil)
  8.   (vl-load-com)
  9.   (setq obj (vlax-create-object "Shell.Application"))
  10.   (setq folders (vlax-invoke-method obj 'BrowseForFolder 0 msg 49))
  11.   (if folders
  12.     (progn
  13.        (setq path1 (vlax-get-property folders 'Title))
  14.        (cond ((eq "桌面" path1)
  15.               (setq path "C:\\WINDOWS\\Desktop\")
  16.              )
  17.              ((eq "我的文档" path1)
  18.               (setq path "C:\\My Documents\")
  19.              )
  20.              (T
  21.               (while index
  22.                  (setq path1 (vlax-get-property folders 'Title))
  23.                  (if (or (eq "我的电脑" path1) (eq "我的文档" path1))
  24.                      (setq index nil)
  25.                      (progn
  26.                          (setq dirlist (append dirlist (list path1)))
  27.                          (setq folders (vlax-get-property folders 'ParentFolder))
  28.                      )
  29.                  )
  30.               )
  31.               (cond ((eq "我的电脑" path1)
  32.                      (setq dirlist (reverse dirlist))
  33.                      (setq path2 (car dirlist))
  34.                      (setq dirlist0 (cdr dirlist))
  35.                      (if dirlist0
  36.                         (progn
  37.                            (setq path (substr path2 (- (strlen path2) 2) 2))
  38.                            (princ "\n")
  39.                            (foreach n  dirlist0
  40.                                (setq path (strcat path "\" n))
  41.                            )
  42.                            (setq path (strcat path "\"))
  43.                         )
  44.                         (progn
  45.                            (princ "\n")
  46.                            (setq path (strcat (substr path2 (- (strlen path2) 2) 2) "\"))
  47.                         )
  48.                      )
  49.                    )
  50.                    ((eq "我的文档" path1)
  51.                      (setq dirlist (reverse dirlist))
  52.                      (setq path "C:\\My Documents")
  53.                      (foreach n dirlist
  54.                           (setq path (strcat path "\" n))
  55.                      )
  56.                      (setq path (strcat path "\"))
  57.                   )
  58.                   (T nil)
  59.               );cond
  60.             )
  61.         );cond
  62.     );PROGN
  63.     nil
  64.   )
  65. )
  66.   [/FONT]
GMT+8, 2026-11-22 08:56 , Processed in 0.237011 second(s), 10 queries , Gzip On, File On.
