查看: 1706|回复: 0
[分享] What's the best way to iterate through an entire Database?
发表于 2013-5-26 18:18:32 | 显示全部楼层 |阅读模式
What's the best way to iterate through an entire Database?                                                        By Philippe Leefsma
  The objects stored in the database get an handle value that gets incremented sequentially, so the fastest approach if one wants to iterate through the whole content of a Database, is to start from handle = 1 to the max handle existing in the Database. P/Invoking "acdbHandEnt" can then help to retrieve the ObjectId from an handle.
  The following C# code illustrates how to do that:
  1. public struct ads_name
  2. {
  3.     public IntPtr a;
  4.     public IntPtr b;
  5. };
  6. [DllImport("acdb19.dll",
  7. CharSet = CharSet.Unicode,
  8. CallingConvention = CallingConvention.Cdecl,
  9. EntryPoint = "acdbHandEnt")]
  10. public static extern int acdbHandEnt(
  11.     string handle, ref ads_name name);
  12. [CommandMethod("IterateDb")]
  13. static public void IterateDb()
  14. {
  15.     ads_name ename = new ads_name();
  16.     Document doc = Application.DocumentManager.MdiActiveDocument;
  17.     Database db = doc.Database;
  18.     Editor ed = doc.Editor;
  19.     ObjectIdCollection validIds = new ObjectIdCollection();
  20.     // now get the last handle in the db
  21.     Handle handseed = db.Handseed;
  22.     // copy the handseed total into an efficient raw datatype
  23.     long handseedTotal = handseed.Value;
  24.     // loop from 0 to the last handle (this could be a big loop)
  25.     for (long i = 1; i < handseedTotal; ++i)
  26.     {
  27.         string handle = Convert.ToString(i, 16);
  28.         // get the ename by converting
  29.         // the long to a hex value string
  30.         int res = acdbHandEnt(handle, ref ename);
  31.         if (res != 5100) // RTNORM
  32.             continue;
  33.         // convert the ename to an objectid
  34.         ObjectId id = new ObjectId(ename.a);
  35.         // check if it's a valid objectId
  36.         if (!id.IsValid)
  37.             continue;
  38.         try
  39.         {
  40.             // open if not erased
  41.             using (DBObject obj =
  42.                 id.Open(OpenMode.ForRead, false))
  43.             {
  44.                 validIds.Add(id);
  45.             }
  46.         }
  47.         catch
  48.         {
  49.         }
  50.     }
  51.     ed.WriteMessage("\nNumber of retrieved valid ObjectIds: "
  52.         + validIds.Count.ToString());
  53.     validIds.Clear();
  54. }
评分
参与人数 1D豆 +2 收起 理由
ScmTools + 2 很给力!资料分享奖!
查看全部评分
GMT+8, 2026-11-22 08:34 , Processed in 0.245292 second(s), 14 queries , Gzip On, File On.
