查看: 1778|回复: 0
[分享] Reloading external reference through .NET
发表于 2013-5-25 02:38:30 | 显示全部楼层 |阅读模式
http://adndevblog.typepad.com/autocad/2012/06/reloading-external-reference-through-net.html
Reloading external reference through .NETBy Virupaksha Aithal
You can use “Database.ReloadXrefs” API to reload the external referenced drawing files. “ReloadXrefs” takes a collection of object ids, which can be prepared by traversing through the block table as shown in below code.
  1. [CommandMethod("ReloadXRefs")]
  2. static public void ReloadXRefs()
  3. {
  4.     Document doc = Application.DocumentManager.MdiActiveDocument;
  5.     Database db = doc.Database;
  6.     ObjectIdCollection ids = new ObjectIdCollection();
  7.     using (Transaction tr = db.TransactionManager.StartTransaction())
  8.     {
  9.         BlockTable table = tr.GetObject(db.BlockTableId,
  10.                                     OpenMode.ForRead) as BlockTable;
  11.         foreach (ObjectId id in table)
  12.         {
  13.             BlockTableRecord record = tr.GetObject(id,
  14.                                OpenMode.ForRead) as BlockTableRecord;
  15.             if (record.IsFromExternalReference)
  16.             {
  17.                 ids.Add(id);
  18.             }
  19.         }
  20.         tr.Commit();
  21.     }
  22.     //now relaod the xrefs
  23.     if (ids.Count != 0)
  24.     {
  25.         db.ReloadXrefs(ids);
  26.     }
  27. }
GMT+8, 2026-11-22 08:09 , Processed in 0.466344 second(s), 10 queries , Gzip On, File On.
