查看: 2880|回复: 0
[分享] Identifying the boundary through API
发表于 2013-5-28 14:54:20 | 显示全部楼层 |阅读模式
Identifying the boundary through API By Virupaksha Aithal
AutoCAD 2011 introduced a new API to identify the boundary objects for a provided point. Below code shows the use of the same API in .NET. The equivalent ObjectARX API is “acedTraceBoundary”.
Note, only visible entities are considered while identifying the boundary objects.
  1. [CommandMethod("BoundaryTest")]
  2. public static void BoundaryTest()
  3. {
  4. Document doc = Application.DocumentManager.MdiActiveDocument;
  5. Database db = doc.Database;
  6. Editor ed = doc.Editor;
  7. PromptPointOptions ptOptions =
  8.                      new PromptPointOptions("Select point ");
  9. ptOptions.AllowNone = false;
  10. PromptPointResult ptResult = ed.GetPoint(ptOptions);
  11. if (ptResult.Status != PromptStatus.OK)
  12.      return;
  13. DBObjectCollection collection =
  14.                ed.TraceBoundary(ptResult.Value, true);
  15. using (Transaction Tx =
  16.            db.TransactionManager.StartTransaction())
  17. {
  18.      ObjectId ModelSpaceId =
  19.             SymbolUtilityServices.GetBlockModelSpaceId(db);
  20.       BlockTableRecord model = Tx.GetObject(ModelSpaceId,
  21.                      OpenMode.ForWrite) as BlockTableRecord;
  22.      foreach (DBObject obj in collection)
  23.      {
  24.          Entity ent = obj as Entity;
  25.          if (ent != null)
  26.          {
  27.              //make the color as red.
  28.              ent.ColorIndex = 1;
  29.              model.AppendEntity(ent);
  30.              Tx.AddNewlyCreatedDBObject(ent, true);
  31.          }
  32.      }
  33.      Tx.Commit();
  34. }
  35. }
评分
参与人数 1D豆 +2 收起 理由
ScmTools + 2 资料分享奖!
查看全部评分
GMT+8, 2026-11-22 08:35 , Processed in 0.421113 second(s), 10 queries , Gzip On, File On.
