查看: 2048|回复: 1
[分享] Using the Table cell selected event
发表于 2013-7-5 07:26:49 | 显示全部楼层 |阅读模式
Using the Table cell selected eventBy Balaji Ramamoorthy
When a table cell gets selected, you may interested in knowing the row and column index of the cell that was selected.
There is no such event in the public API but the "Autodesk.AutoCAD.Internal.Reactors" does provide one such event. Please note that the use of any API which is part of the "Internal" namespace is unsupported and subject to change. So, if you decide to use it, please test it thoroughly to see if it works correctly in your plugin.
Here is the sample code to use the "CellSelected" event from the "Autodesk.AutoCAD.Internal.Reactors.TableSubSelectFilter" class.
  1. using Autodesk.AutoCAD.Internal.Reactors;
  2. void IExtensionApplication.Initialize()
  3. {
  4.     TableSubSelectFilter tsf = TableSubSelectFilter.Instance();
  5.     if (tsf != null)
  6.     {
  7.         tsf.CellSelected
  8.             += new TableSubSelectFilterEventHandler(tsf_CellSelected);
  9.     }
  10. }
  11. void IExtensionApplication.Terminate()
  12. {
  13.     TableSubSelectFilter tsf = TableSubSelectFilter.Instance();
  14.     if (tsf != null)
  15.     {
  16.         tsf.CellSelected
  17.             -= new TableSubSelectFilterEventHandler(tsf_CellSelected);
  18.     }
  19. }
  20. void  tsf_CellSelected(object sender, TableSubSelectFilterEventArgs e)
  21. {
  22.     if (! e.TableId.IsNull)
  23.     {
  24.         using (Transaction tr
  25.             = e.TableId.Database.TransactionManager.StartTransaction())
  26.         {
  27.             Table table
  28.                 = tr.GetObject(e.TableId, OpenMode.ForRead) as Table;
  29.            if (table.HasSubSelection)
  30.             {
  31.                 CellRange cr = table.SubSelection;
  32.                 System.Diagnostics.Debug.WriteLine
  33.                     (
  34.                         String.Format("\nSingle Cell ? : {0}",
  35.                         cr.IsSingleCell)
  36.                     );
  37.                 System.Diagnostics.Debug.WriteLine
  38.                     (
  39.                         String.Format("\nTop row : {0}",
  40.                         cr.TopRow)
  41.                     );
  42.                 System.Diagnostics.Debug.WriteLine
  43.                     (
  44.                         String.Format("\nLeft column : {0}",
  45.                         cr.LeftColumn)
  46.                     );
  47.                 System.Diagnostics.Debug.WriteLine
  48.                     (
  49.                         String.Format("\nBottom Row : {0}",
  50.                         cr.BottomRow)
  51.                     );
  52.                System.Diagnostics.Debug.WriteLine
  53.                     (
  54.                         String.Format("\nRight column : {0}",
  55.                         cr.RightColumn)
  56.                     );
  57.             }
  58.             tr.Commit();
  59.         }
  60.     }
  61. }
评分
参与人数 1D豆 +3 收起 理由
ScmTools + 3 很给力!经验;技术要点;资料分享奖!
查看全部评分
发表于 2013-7-5 21:50:56 | 显示全部楼层
很直观的“CellSelected”事件示例代码使用
GMT+8, 2026-11-22 08:15 , Processed in 0.247593 second(s), 12 queries , Gzip On, File On.
