查看: 1293|回复: 0
[VBA程序]:如何获得XREF文件的路径
已领礼包: 145个
发表于 2002-10-9 13:55:35 | 显示全部楼层 |阅读模式
  1. [FONT=courier new]
  2. How to get the path of an inserted xref?
  3. ID    33923
  4. Applies to:    AutoCAD 2000
  5. This document is part of    Block Reference   COM-ActiveX Interfaces   VBA   Xrefs
  6. Question
  7. How can I get the path of an attached (inserted) external reference (xref) with
  8. ActiveX?
  9. Answer
  10. Use the ObjectIdToObject to reference an AcadBlockReference to an
  11. AcadExternalReference object. The external reference object has a path property
  12. that will return the path of the Xref.
  13. Here is a VBA example:
  14. Public Sub getXrefPath()
  15.   ' Declare two variables for a block reference and external reference
  16.    Dim pt As ACAD_POINT
  17.    Dim ob As AcadObject
  18.    Dim xR As AcadExternalReference
  19.
  20.    ' Select an Object in AutoCAD
  21.    ThisDrawing.Utility.GetEntity ob, pt, "Select an XREF: "
  22.
  23.    If (ob.ObjectName = "AcDbBlockReference") Then
  24.
  25.         On Error GoTo TypeError
  26.
  27.             ' Reference an AcDbBlockReference
  28.             Set xR = ob
  29.             ' Print the path in the immediate window
  30.             MsgBox xR.Path
  31.             Exit Sub
  32.
  33. TypeError:
  34.             MsgBox "This is not an XREF!"
  35.             Exit Sub
  36.
  37.         Resume Next
  38.
  39.    Else
  40.
  41.         MsgBox "This entity is of type: " + ob.ObjectName
  42.
  43.    End If
  44. End Sub[/FONT]
GMT+8, 2026-11-2 22:22 , Processed in 0.577491 second(s), 30 queries , Gzip On.
