查看: 1672|回复: 0
[LISP函数]:类似acet-str-format
发表于 2007-12-19 09:52:02 | 显示全部楼层 |阅读模式
  1.   [FONT=courier new]
  2. ;;; ==================================================================
  3. ;;; 类似acet-str-format
  4. (defun th-str-format (str newstrlst / n oldstr oldstrlst)
  5.   (setq n 0)
  6.   (setq oldstrlst (mapcar
  7.                     (function (lambda (x)
  8.                                 (setq n (1+ n)
  9.                                       oldstr (strcat "$" (rtos n 2 0) "#")
  10.                                 )
  11.                               )
  12.                     )
  13.                     newstrlst
  14.                   )
  15.   )
  16.   (mapcar
  17.     (function (lambda (a b)
  18.                 (setq str (th-str-repl a b str))
  19.               )
  20.     )
  21.     oldstrlst
  22.     newstrlst
  23.   )
  24.   str
  25. )
  26. ;;; 测试
  27. ;;; 命令: (th-str-format "\ncollecting all $1# objects on layer $2#..."
  28. ;;; (list "12"
  29. ;;; "23"))"\ncollecting all 12 objects on layer 23..."
  30. ;;; 命令: (th-str-format "\ncollecting all $1# objects on layer $2#..."
  31. ;;; (list "12"
  32. ;;; "23" "45"))
  33. ;;; "\ncollecting all 12 objects on layer 23..."
  34. ;;; 命令: (th-str-format "\ncollecting all $1# ob$1#jects on layer $2#..."
  35. ;;; (list "12"
  36. ;;; "23"))
  37. ;;; "\ncollecting all 12 ob12jects on layer 23..."
  38. ;;; 命令: (th-str-format "\ncollecting all $1# objects $3#on layer $2#..."
  39. ;;; (list "12"
  40. ;;; "23" "ab"))
  41. ;;; "\ncollecting all 12 objects abon layer 23..."
  42. ;;; ==================================================================
  43. (defun th-str-repl (curchar newchar str)
  44.   (while (vl-string-search curchar str)
  45.     (setq str (vl-string-subst newchar curchar str))
  46.   )
  47.   str
  48. )
  49. ;;; ==================================================================
  50.   [/FONT]
GMT+8, 2026-11-22 10:41 , Processed in 0.386977 second(s), 10 queries , Gzip On, File On.
